GM cars are notorious for being both metric and SAE. I'd be interested to know if any 2018 models are completely metric.
I wouldn't recommend anyone focusing on the metric system mathematically, as it doesn't help you with one of the basic building blocks of everyday math, which is fractions. Learn that and how to manipulate and work with them and you will find that you already know metrics.
So what are ratchets? Does the purely metric world use the same 1/4", 3/8", and 1/2" and just call them 6, 19, and 13mm or do they have an actually different size drive?
I actually think it would be great if we could get our raw materials on board with the metric dimensions.
Anything less than an even multiple of 1 unit of anything is a fraction. 1"=25.4 mm - looks like a fraction of something to me.
You do realize that if we used the metric system we would not need to understand complicated fractions......
You do realize there is a reason that fractions came about, and that they are used, colloquially, universally? Also, do you know what a lini, an arshin or a chain is? Or that Japanese property is measured in tatami?
When you ask your wife if she wants any steak or chicken or salad, does she say "yes, given me a third of that." Or does she say "No, I don't need that much, give me .3333333333333... of that"
I loathe SAE. This country should've gone metric 100 years ago. Ugh.
Ratchets are pretty universal, world wide, for drive end size, that is, 1/4", 3/8" and 1/2". However you will see references to 6.35, 9.5, and 12.7mm drive sizes from our metric friends.
What about tires? 16-225R60. That's a 16" rim with a 225mm wide tread a 60% aspect ratio (technically a dimensionless number). Funny thing. When I was in Japan 20 years back they advertised their TVs in inches even though the entire add would be in Japanese. I believe I noted they also used that hybrid inch-metric tire sizing.
THe only metric that’s caught on on the US is the 9 millimeter
And hey
They’re are two types of countries in the world
Those that use the metric system
And
Those that have been to the moon !
Coulda, woulda, shoulda been 10mm. Long live Col. Cooper.
These threads are fascinating to me for a bunch of reasons...
3. My project hardware is all SAE. Mind blown by 2ndgearrubber's metric project hardware! If anyone knows where to find stainless coarse- thread metric wood screws, let me know... I'm short some screws for my Tacoma. I don't think I've ever seen a metric lag bolt either...
JR
My buddy has an '82 AMC eagle, with a Jeep 4.0 swap. Metric, SAE, Torx, E-torx, 12 point. Sometimes metric heads with SAE pitches and vice versa!Coulda, woulda, shoulda been 10mm. Long live Col. Cooper.
1. SAE tools are available everywhere used for cheap, I'm working on collecting all the weird dead x/32" stuff and have SAE basics to last my lifetime, bought new, cheap.
2. Everything attached to your house is probably SAE, like your plumbing.
4. 12 is divisible by more numbers than 10, helping with layout. Chris Schwartz has written a fair bit about it. For simple layout work, apparently, inches are better.
5. The US never really switched to metric... nor Liberia, nor Myanmar... not sure if that's good company or not!
6. My very limited "mechanic" experience was working on old IH farm stuff (all basic SAE stuff) and 1970's trucks - all SAE.
7. This is GJ. You shouldn't quit until you've got all the dead x/32", Whitworth, pre- war USS, and any other weird size you can find!
I can finally consistently remember how this works, and it's frankly just nuts. I should look into how Europeans size tires, 'cause it can't possibly be so weird.
JR
I was under the impression that "screws" were neither metric or SAE in pitch. The only thing that could potentially be either is the center diameter, the "screw" section was just a spiral at a specified slope. I guess the slope has to be measured in something at some point, right?
Project "hardware" to me is actually threaded items that you can buy as nuts/bolts. Never really considered nails, screws, and whatnot threaded hardware, although I suppose they are. I buy that stuff based on whatever material I'm working with and its requirements. I was referring to hardware for cars/motorcycles mainly. Although I did use metric hardware to install my shower curtain rod holders.
A screw with a diameter of 3/16, and a T30 torx head. Metric or SAE?My buddy has an '82 AMC eagle, with a Jeep 4.0 swap. Metric, SAE, Torx, E-torx, 12 point. Sometimes metric heads with SAE pitches and vice versa!
There is actually a discussion among some mathematicians that the world would have been better if we used a base 12 vs base 10 number system. It's worth noting that in ancient times numbering systems weren't always base 10. Anyway, the argument is that 12 is a better number because it can be evenly divided into the fractions we use most commonly, ie 1/2, 1/3, and 1/4. Base 10 can only be divided evenly by 1/2. 1/4 at 0.25 isn't too bad but 1/3 of course is a rather impractical 0.3333(repeat that 3 until the end of time).
If we had such a system then the benefits of things like the metric system (every unit an is a clean decimal shift from the previous one) would be retained, but we would also get the very useful fractional numbers that are natural to work with (especially in geometry and layouts). A bit off subject but least anyone think that Metric is an all together better system, no, it just that the compromises are less awkward vs those in SAE units.
And I'll take an Imperial pint, cheers!
And
Well it’s not “just” one country that hasn’t switched
It’s 28% of the worlds economy
We have all the money
We can use whatever system we want
