That's some amazing work, Andy.
BTW, according to the movie Pulp Fiction, in France the Quarter Pounder is called a "Royale with Cheese".
Thanks, Jim! I'm having fun now!!
Maybe I should be going to the movies...
Andy your mounts are just awesome, well done and thank you for sharing.
Thanks Steve!! This was my original goal of taking up casting, and I almost chickened out and made them from steel.
That wire is good stuff, I always try to keep some around.
The only trouble I've had with aluminum motor mounts is sometimes the torque to yield bolts bring the threads along when you remove them. Thanks VW.
I've thrown away a lot of wire over the years. This is my current pile at the barn.
Baling wire is interesting. It is a little larger and stiffer than tie wire,and makes much better repairs. It also makes great oxy-acetylene welding wire. It must have a high silicon content, it welds as good as E70S-2. I have a couple of partial boxes in the shop that became tangled. A lifetime supply, or two or three. Or four. You bet I keep some in my truck.
I'm not up on the nuances of properly threading aluminum. These mounts use through bolts. I have enjoyed the VW frailties. Although VW engines and transmissions were magnesium, I believe.
Thank you, thank you, thank you!!!
Hey Andy, I haven't been around much lately - so I thought I'd drop in and say G'day. I went back a few pages (which was probably only a few hours in real time) - the cast engine mounts are definitely very cool.
Sent from my SM-G950F using
The Garage Journal mobile app
Thank you!
WOW!!! You are the MAN, those motor mounts are very, very cool. I don't think many street rods or any car for that matter has owner cast parts like yours has.
Thanks for taking the time to share your shop time with us.
Man I love the kind words! The motor mounts are a little rough, but I'm going to get better.
Andy,
Catching up after being off and the engine mounts are great, much more thought and effort than what is required but very cool all the same. I did a quick search for aluminum mounts and found a few even some for the LS Bret. I have some high quality ($$$) aluminum I need to bring you from a recent project I'll post about shortly.
JB
Thanks, JB! The motor mounts went quicker than I expected. Had I finished them from steel I think it would have been about the same or a little more time. Part of my dilemma was to not weld to the old frame but still have a three point attachment. so it's a little busy.
I hate to be greedy for more aluminum, but I am.
Ok, so I'm doing a hot rod build of a '52 COE. I say I just move down to your place and have you knock out a bunch of custom cast pieces for me.
Seriously, the motor mounts look awesome.
OK, I'll make space in the shop, you just have to help with some of the two-man jobs. We can put it on the four post lift when I get the Dodge off.
Thanks for the kind words.
Really have nothing to add but absolute admiration Andy.
So you've been to my little foundry and have cut some foam. Thanks for the good words!!
At least you'll never run out of wire to tie stuff up with!
Nor would I want to run out.
I had a guy tell me one time "an overhaul doesn't just mean changing out the baling wire". What did he mean? When I lost a drawbar bolt and my baler drawbar fell to the ground in a remote field (1/4 mile down a steep winding trail) and I had few tools, I drug it to a gully and dropped the tractor in the gully, bringing the drawbar back up. Then I put 50 turns of baling wire around it (plenty when you have the baler with you) and it held fine when I drove out. I finished baling the field and really hated to cut it loose at home.
Andy: I've never changed an engine, but i also appreciate the skills you have and the talent you showed in making a new part from scratch that will probably work better on the car than the day it left the factory.
WELL DONE!!
Thanks, Drives
I appreciate all the kind words, guys. They are very motivational.
So now the ugly truth:
My woodcutter called me, frantic. His boat is in the lake and he bent his trailer axle, ruining the rim. I told him to bring it over. It was bent.
I forgot to take a picture until I had started warming it. The inboard bearing race slides down the long piece so I can't beat on it without dinging it up and grinding a lot. So I heated it and bent it with a long pipe.
****! I could not get it hot enough close enough to the step and wound up with an S shape. In the picture it looks like it was over bent, but I don't think so. The axle was horizontal in the vise and it is bent right at the step. He says he only drags it ten miles to a local boat ramp. Tapered roller bearings are pretty forgiving, and it turned nicely when we put the hub back on. I asked him to bring a new spindle and I'd change it over the winter when he is not using the boat. But it may run many years. He really needed the boat out of the water today and at least we met that goal.
The good, the bad, and the ugly. This was bad and ugly.
