Crazyjake8493
I was looking at this pegboard online: https://www.lowes.com/pd/Blue-Hawk-1-Piece-Steel-Pegboard-Actual-16-in-x-16-in/50220687
The pic shows the mounting holes on the edges, and at 16" wide, this works for the 4-drawer cart. But the reviews say the mounting holes are 12" apart. Did you have to run some flat bar or similar material between the cart's uprights in order to mount the pegboard, or did you bypass the mounting holes and secure the pegboard to the cart's uprights?
Edit: I think I figured it out - those holes along the edges aren't mounting holes, they are meant to secure adjacent panels to one another so that pegboard hole spacing is continuous across panels. The actual mounting holes are a couple of inches in from the edge. So for attaching to the cart's uprights, probably easiest to use one of the pegboard holes along the edge (enlarging as necessary for fastener to be used).
That's correct. I'd have to look at mine, but if I remember right I cut those tabs off and drilled holes in the cart uprights to line up with 4 holes of the pegboard, and used a 1/4-20 machine screw and nut to attach them. I had bought a piece of 16x16" steel pegboard from Lowes and a 16x16 plastic piece from HD, and put one on each side of the bottom of the cart.
