Between 265 & 485 SQ/FT Subterranean Two Car Garage
pjmariner
Marshfield MA
Hi,
I have been lurking for several years, gleaming ideas and inspiration so its about time I contribute.... I need 5 post before I can add pctures apparently so....
P
pjmariner
Marshfield MA
...here is post number 2. I bought my house about 2 years ago, after searching long and hard for an affordable house with a 2 car garage so I can move all my tool in and build a new shop, similar but better by learning from my first shop what I want to change...
P
pjmariner
Marshfield MA
...I always wished in first shop I did something with cement walls, and since this garage is a 2 car under, with only the front wall exposed, I have a lot of cement in this garage to deal with. The upside is it remains about 15 degrees cooler in the summer, and 15 degrees warmer in the winter than outside temp with no heating or cooling.
P
pjmariner
Marshfield MA
....Hence the name subterranean garage. When I moved in I only added lights to garage and painted ceiling, and since I was redoing most of the interior before I moved in, including a complete kitchen remodel, the garage sadly had to wait.... Since I have a full time job and I did 90% of all renovations by myself the house took me about a year to finish working at night and weekends between kids practices etc
P
pjmariner
Marshfield MA
I have lots of pics of the house renovation I may share later, but for now I will stick to the garage..
Here it is on day I closed, it is 18' deep, 24' wide, and ceilings a touch over 7 feet....
wood doors with serious moisture issues..
IMG_0762 by https://www.flickr.com/photos/120925262@N04/, on Flickr
shelves I removed...
IMG_0763 by https://www.flickr.com/photos/120925262@N04/, on Flickr
pegboard that was run all the way down to the floor and sucked up moisture and mold....
IMG_0764 by https://www.flickr.com/photos/120925262@N04/, on Flickr
More shelving I removed...
IMG_0765 by https://www.flickr.com/photos/120925262@N04/, on Flickr
wall to wall view, complete with annoying pole in the middle just like last garage
IMG_0771 by https://www.flickr.com/photos/120925262@N04/, on Flickr
IMG_0772 by https://www.flickr.com/photos/120925262@N04/, on Flickr
One of first things I bought for house, And a huge key to garage happiness I learned the hard way from last gargage, here is my 12x8 shed to keep bikes/tractors/yard toys etc out of the garage. Nothing worse then clutter and **** in my worshop. The shed is covered in LP smart siding which I ended using to panel walls in shop. It is good stuff. I debated buiklding a shed, but having this delivered assembled and ready to go was a huge time saver and well worht the cost.
IMG_0933 by https://www.flickr.com/photos/120925262@N04/, on Flickr
I added a shelf accross back for snow tiers etc, and stretchers across roof for rakes and shovels...
IMG_1242 by https://www.flickr.com/photos/120925262@N04/, on Flickr
P
pjmariner
Marshfield MA
First thing I did was painted sewer pipes and support poles with rust converting paint after wire brushing off heavy stuff
IMG_0869 by https://www.flickr.com/photos/120925262@N04/, on Flickr
Next I patched and painted ceilings, you can how dingy they were...
IMG_0870 by https://www.flickr.com/photos/120925262@N04/, on Flickr
Here is my ligthing, there are 12 total 4 foot leds on this worshop side of the garage, this is side where tools will stay, other side will be open to park car and used as assembly area for large projects. The other side has 8 lights total. I added outlets where the old single light bulbs were so I could run them off existing light switch. The old garage doors were so close to the ceiling, I had to hang half the lights from uni-strut, and door actually goes over them. It worked pretty good. When I replaced doors I went with 6'6" door for a better fit and I was able to get lights flush to ceiling. But for those who want lights to be useful when garage door is up, this could be a good idea. I prefer my lights on the ceiling since they are only 7' to start with.
Now with enough lighting so I could see what I am doing, this would be the last thing I would do on garage for about a year, as my focus at that point became renovating house so I could actually move into it at some point.
IMG_0891 by https://www.flickr.com/photos/120925262@N04/, on Flickr
IMG_0861 by https://www.flickr.com/photos/120925262@N04/, on Flickr
P
pjmariner
Marshfield MA
Last December finally replaced garage door, good bye wood, hello insulated steel. Doors are 6"6 tall, which allows lights to fit under door, liftmaster lift on the car side door, Azek trim all around the door openings.
226F1149-CEDA-405D-91CD-AAF81C0761BD by https://www.flickr.com/photos/120925262@N04/, on Flickr
36CD8C77-63A1-4429-B1F2-A548C5B20289 by https://www.flickr.com/photos/120925262@N04/, on Flickr
51291355-49AF-4C51-AD07-2A8C11DE8A13 by https://www.flickr.com/photos/120925262@N04/, on Flickr
Now I can remove uni-strut hanging lights and have lights flush mounted on ceiling, more headroom and better light reflection
BE89DA82-6DB8-49B2-A2E4-D8534EDAA110 by https://www.flickr.com/photos/120925262@N04/, on Flickr
P
pjmariner
Marshfield MA
A few weeks ago I finally bought supplies to finish the walls in my garage. 17 sheets of LP smart siding, a pile of 2x3s a case of PL premium, and a couple boxes of yellow ramset bullets and pins and I am ready for action
ED1CFED4-0BD4-4FDF-9993-595C80496FAC by https://www.flickr.com/photos/120925262@N04/, on Flickr
5F3D07FD-D352-41CF-8739-41E69A80A743 by https://www.flickr.com/photos/120925262@N04/, on Flickr
I buttered up each 2x3 with pl premium, laid them on their face and attached them about 3 inches up from floor to top of the cement portion of wall. The cement is very hard and most pins need 2 loads to get driven flush, and I had several just blow out and crumble in the concrete. but with persistence I got them all up.
The idea here is to keep panels off the floor, off the wall and shy of the ceiling, this will allow air to circulate behind them and keep them dry and mold free. The LP smart panels are very water resistant, so I have no worries about them in this install.
79EB4B89-008E-4A5D-9E82-0ED45AC469CF by https://www.flickr.com/photos/120925262@N04/, on Flickr
A5FFC9B9-4FCB-424B-AE57-37A5925EA4AE by https://www.flickr.com/photos/120925262@N04/, on Flickr
With 2x3's up I ran 12-3 romex for my multi-circuit wiring. I am going to put about 20 4 square surface mounted boxes on the paneling. By surfacing mounting boxes if I every want to expand I can run conduit and surface mount new box wherever necessary. I will have 1 white and 1 almond duplex outlet in each box, one for each circuit, that way I can run a vacuum and tool on separate circuits at every 4 square box. I am using a bi-pole 20amp GFI circuit breaker and standard outlets. More to come on the wiring...
53A05D31-3357-4915-A817-E93C855FB80D by https://www.flickr.com/photos/120925262@N04/, on Flickr
58A2EB8B-F117-4F08-92B9-9B5AF584F978 by https://www.flickr.com/photos/120925262@N04/, on Flickr
5662E07E-51B9-4264-90F7-8A28061D01E3 by https://www.flickr.com/photos/120925262@N04/, on Flickr
651EB2FB-E8BF-4BAE-BE44-4A93CCE73739 by https://www.flickr.com/photos/120925262@N04/, on Flickr
3A7DD501-3CE9-4288-A97B-0B352576BF16 by https://www.flickr.com/photos/120925262@N04/, on Flickr
P
pjmariner
Marshfield MA
This is my little invention that proved a life saver. I took the plate off my floor jack, and drilled holes in it and counter sunk them so I could attach wood for a "fork lift". This will allow me to put the panel on the jack and hold them in place while I adjust and attach them to the wall with pl premium and finish nails. Since I work by myself this was super handy since I want the panels for the walls to be flush at the top and bottom and equidistant to the ceiling. the floor pitches towards the garage door so shims would not work well as every panel closer to the garage door is a bit higher off the floor than the last.
43428319092_64fc4bb010.jpg99D5A006-EA2D-4780-B534-4927A86034EE by https://www.flickr.com/photos/120925262@N04/, on Flickr
43428319302_656d65d40b.jpg199D6B52-9EA8-4838-8E35-99E69B0B2395 by , on Flickr
43428320042_53c60b32f1.jpg8C88C669-B625-4B9D-8E37-59AE170FB60E by https://www.flickr.com/photos/120925262@N04/, on Flickr
43476771011_f31d6f06a3.jpgF15EB89D-44EA-4CC4-8AAD-CFEF7F6F4FF5 by https://www.flickr.com/photos/120925262@N04/, on Flickr
02blueru
Subscribed! I have a split entry home with the same partially finished walls and was going to commit to just painting them and running conduit. Interested in how it turns out.
P
pjmariner
Marshfield MA
Thanks. I debated the same thing for awhile. Conduit done right looks slick, but this solution was super simple. Hardest part was phishing wire across ceiling. I did all the rough wiring in about 2 hours. I have six boxes I will put on front of workbench that will run along shop wall once I frame that out. Best part is with the surface mounted boxes I can add more outlets easily using conduit in the future.
Platonic Solid
CT-USA
I have a similarly low garage ceiling. When I originally ordered my low headroom garage doors from Clopay they came with the double track as you have. After installing the first of 2 doors I was immediately dissatisfied. I found the cable protrusions into the space to be an unacceptable hazardous annoyance. Additionally the tension of that system pulls the bottom panel away from the house enough to create a convenient criter entrance. I exchanged the double track for single track with 12" radius and quick return brackets. This put the cable out of the way (like standard height garage doors) and allowed the bottom of the door to sit flush to the wall. The "super sneaky" brackets may work also (with single track), but I didn't try those.
P
pjmariner
Marshfield MA
Here is the paneling going up, i kept it about 1.5 inches from ceiling and 2.5 inches from floor to allow for airflow behind panels. I love the primer color on this paneling, a nice tan/beige, since I am primarily a woodworker it will help hide all the saw dust. I have some exterior paint color matched to the primer so I can paint the walls sections I don't panel, as well as any touch-up etc to the paneling it self.
A0BA91A9-BE45-467F-996F-19BB511CF8DF by https://www.flickr.com/photos/120925262@N04/, on Flickr
91B29C51-53B5-44F2-B98D-2F2A8D863E8A by https://www.flickr.com/photos/120925262@N04/, on Flickr
B3C3814C-030C-4F79-A644-64236CE1A7C1 by https://www.flickr.com/photos/120925262@N04/, on Flickr
I built a removable valance to cover all the wires coming into panel. it just sits on top of panel.
76FCD7AF-797A-47B7-B92D-B6C5B62BAE18 by https://www.flickr.com/photos/120925262@N04/, on Flickr
I had debated trim or no trim on panels, once it was up I decided it needed something to finish it off near the ceilings/corners. I ended up ripping 1.5" strips of leftover paneling to create the trim. I had plenty of drops from the paneling and is already painted to match.
D3CAE5B6-A524-4FEB-A48B-325D8D53FDFA by https://www.flickr.com/photos/120925262@N04/, on Flickr
2976ECBC-882E-44DD-99EC-F9224E916031 by https://www.flickr.com/photos/120925262@N04/, on Flickr
EC4F23EC-5930-4DF8-9169-A1E824253523 by https://www.flickr.com/photos/120925262@N04/, on Flickr
P
pjmariner
Marshfield MA
I decided where sewer pipe is to stop paneling about 65" up the wall, then I will paint wall same color as the paneling
76206351-03C5-45A7-8089-7F3E36287B86 by https://www.flickr.com/photos/120925262@N04/, on Flickr
22611E78-6038-4BEC-9F19-77A8F7B0D086 by Matthew Follett, on Flickr
When I got to far corner of garage, i notice the plaster incorner is spongy and 2x4 sill plate is rotten... after digging around i removed all the plaster and found corner of garage had some signifcant damage. Since I plan on residing house in next couple years, i decided to cut out rot and graft in new sheeting so i could save original shingle for now.
43A4D309-55EF-4C27-AF3D-8BF35D54377F by https://www.flickr.com/photos/120925262@N04/, on Flickr
77DA195D-1CC7-44CE-B2CB-3A542D8224CE by https://www.flickr.com/photos/120925262@N04/, on Flickr
6FE01800-AEB7-4B8E-98FC-9771A2069799 by https://www.flickr.com/photos/120925262@N04/, on Flickr
I cut out rotten section, and replace sill plates with pressure treated 2x4 and copious amounts of construction adhesive.
81D67041-4ACB-4E9A-83BA-45B655401EF5 by https://www.flickr.com/photos/120925262@N04/, on Flickr
I then added flashing between old sheeting and inside sheeting repair I made with Azek board. On outside added new azek trim, and replaced trim on other side of house while I was at it, thankfully no rot on that side
585B22E9-0DB8-4C40-80F9-8C9523C77769 by https://www.flickr.com/photos/120925262@N04/, on Flickr
20279BC8-8334-4533-8E74-63D4F85C6E3D by https://www.flickr.com/photos/120925262@N04/, on Flickr
11DEB49A-3B9E-4D28-828B-CFA23BC6F38E by https://www.flickr.com/photos/120925262@N04/, on Flickr
with the rot dealt with it was back to the paneling.
B17DB16A-4B1C-4D9F-B9CC-DE9F71B6D867 by https://www.flickr.com/photos/120925262@N04/, on Flickr
D9FABCD8-2C75-46EB-AF5B-684C942D6DBF by https://www.flickr.com/photos/120925262@N04/, on Flickr
E6A40553-ED0B-42DC-BBA5-AAF21222BB3D by https://www.flickr.com/photos/120925262@N04/, on Flick
That is all the progress I have made to this point. This weekend I plan a much needed garage vacuum/leaf blowing session, and then I will paint the exposed plaster and touch up the panels where needed
P
pjmariner
Marshfield MA
That is good to know, The wires are indeed a bit of hazard /nuisance, I may look into that.
James-W
Southeastern Wisconsin
The garage is coming along nicely, but I have a question. How do you keep water from running down into the garage? It would seem to me that with the garage underground like that and with a slope going down to it, there will be a water problem.
P
pjmariner
Marshfield MA
Good question. In nearly 2 years since I’ve owned house with some serious snow and storms I have never had water in the garage. There are 4 large steel grates, with French drain in front of the garage doors at lowest point of the driveway. After the grates the driveway starts to pitch other direction as you enter garage . Also, the top of my driveway has a hump keeping it about four inches above road level, and keeping any runoff out of the driveway.
P
pjmariner
Marshfield MA
Finished hanging last couple of panels, and painted all the exposed walls, door, trim etc the same color as the paneling.
Next Step is a needed clean up, outlet wiring, and start the Miter station/workbench/storage that will run the full length of the left wall.
I have quite a few cools idea for the bench I am still hashing out.
8DC5E947-1744-432D-8C90-09A310A45A82 by https://www.flickr.com/photos/120925262@N04/, on Flickr
DB0BDC52-CDDC-4C3C-A773-2FEBA6DBB53E by https://www.flickr.com/photos/120925262@N04/, on Flickr
E889E11A-FF5E-47FF-9D65-6E124F3AC48E by https://www.flickr.com/photos/120925262@N04/, on Flickr
83101206-AEC9-416D-9BBD-FE733BC94B46 by https://www.flickr.com/photos/120925262@N04/, on Flickr
C02AE269-12A9-4F6F-A8AD-F7DA9620A173 by https://www.flickr.com/photos/120925262@N04/, on Flickr
P
pjmariner
Marshfield MA
Outlet wiring
Started wiring my outlets. As I mentioned earlier, I am doing a multi-circuit run with 12/3 romex with ground and double pole 20amp GFCI breaker.
Since the 2 circuits share a neutral you need to pigtail connections. One big added benefit to this is I can do the majority of the outlet wiring sitting comfortably at my table. Once this process is done and the boxes are prepped all i need to do is make connections and attach cover. I am using wago's for the connections, so the amount of fiddling with wires at the box is minimal, hopefully speeding things up and reducing frustration/increasing my sanity. I using wagos for the connections.
Here is my pigtail pile,
29242636337_48f9177265.jpg4A508838-2F3D-4694-A24C-DD7EEE5E103D by https://www.flickr.com/photos/120925262@N04/, on Flickr
Here is one cover completed and ready to go
43461743664_5ec18c7246.jpgD0A40DA4-BDC6-4B66-BCE1-32F2EBB56D19 by https://www.flickr.com/photos/120925262@N04/, on Flickr
29242627947_7d16321757.jpgB7BAD453-FE72-48F7-87A2-76C07977E290 by https://www.flickr.com/photos/120925262@N04/, on Flickr
Here is the connection with the wagos at the box. This is the last box in the run if you wondering where the rest of the wires are. This is the only box I have mounted to wall yet and I was curious how it would all work/look/etc so I decided to wire this one first.
Next step is to mount all the boxes, prep them all, prep all the outlets, wire the breaker into panel, etc.
44179976191_441a94d941.jpg6EE45C2A-8FD6-47BA-A93F-AA7E5FF06465 by https://www.flickr.com/photos/120925262@N04/, on Flickr
29243129217_f60dcb90dc.jpg246ADF12-D0E1-4A99-AE43-FC4995DD4D17 by https://www.flickr.com/photos/120925262@N04/, on Flickr
44179974091_b3fa6945a7.jpgB83C9475-EA67-416A-93D4-2D8E61106D1B by https://www.flickr.com/photos/120925262@N04/, on Flickr
One down about 19 to go :wtf:
Terrick down Under
Royalla, NSW, Aust.
Great work so far, I have just used a very similar looking product down here for the exterior sections of our house, but it is Fibre cement board. Waiting to see your ideas for the benches.
P
pjmariner
Marshfield MA
The products do look similar. I think the engineered paneling has come a long way in recent years. Was the fiber cement easy to work with? I know here some of the Hardin-siding can be a bit difficult because of all the fiber/cement dust etc.
Platonic Solid
CT-USA
Thanks for introducing me to this product. I'm going to use it on the outside of my shed rehab.
BlueBomber
Outside Boston, MA
A nicely transformed space, and good thinking on the electrical approach. You must have a tolerant better half to be able to work on all that wiring at your table.
P
pjmariner
Marshfield MA
Taking a break from the garage for a minute, here is a bit more on my living room where i was doing the wiring, it was part of my never ending home renovation project...
This is what it looked like when I bought it
IMG_0911 by https://www.flickr.com/photos/120925262@N04/, on Flickr
Here it is after paint, floors refinished and my sectional I absolutely love.
CF5C7B6F-8DA2-48C0-8C48-493DE623FCFB by https://www.flickr.com/photos/120925262@N04/, on Flickr
The old mantle was very plain, flat, was splitting at the seems, and did not fit with my audio visual needs so I took it down.
016A184E-F143-44E2-A7B6-43232BB2012F by https://www.flickr.com/photos/120925262@N04/, on Flickr
I made a shaker style mantle that will add dimension to the wall, plus leave room for me to run all my audio and visual wires
E56F296F-F263-4746-8C68-28A2B2BFF0DF by https://www.flickr.com/photos/120925262@N04/, on Flickr
4DCB1EF9-EC73-45F1-98B6-33A3409817E5 by https://www.flickr.com/photos/120925262@N04/, on Flickr
The last pieces of trim will cover the screws mounting the mantle. The mantle top is removable to aid in wiring
In the bottom left of picture you can see my coffee table which is a chunk of maple from my neighborhood bowling alley growing up, wrapped in mahogany with mahogany legs, I don't know if I have any more pics on that project, I built it about 10 years ago.
6DC5FBB2-28A6-4DEE-84B0-5B8E10DE5585 by https://www.flickr.com/photos/120925262@N04/, on Flickr
Here it is painted and installed, with a 65 inch Sharp 4k tv
47EAD290-72C4-4A8A-959C-3CD7F8AFA092 by https://www.flickr.com/photos/120925262@N04/, on Flickr
I used low voltage recessed wall plates to finish mantle where wires come out. i have one at the bottom of each mantle leg, and one under the TV. Unlike running wires through the walls i can easily add or remove wires from this setup and still hide all wires.
ABE267B9-2339-4DA9-BD2F-177B850D5D7D by https://www.flickr.com/photos/120925262@N04/, on Flickr
693113A0-4519-4C4F-944F-1461EC8CD1E6 by https://www.flickr.com/photos/120925262@N04/, on Flickr
9790684E-A1A6-4A1E-9553-55A7F1B7C97B by https://www.flickr.com/photos/120925262@N04/, on Flickr
Here is my mid-fi collection of used mostly american 2.1 channel audio.
Carver a500x amp
AMC CD9 cd player
B&K PT3 series II preamp
Esinkin Blue tooth adapter *single greatest $20 i have ever spent. Once you stream music through a real stereo system you will never want to stream through some rechargeable mini speaker again, simply no comparison.
Speakers are Acoustic Energy Aesprit 309
sub is a Bic f12
04F200D4-CFB1-496B-9413-57CFA8B6210C by https://www.flickr.com/photos/120925262@N04/, on Flickr
P
pjmariner
Marshfield MA
Re: Outlet wiring
I must be slightly OCD as the mismatched outlet colors would drive me nuts.
Real nice work on that mantle :thumbup:
I get the OCD thing. In my mind the thought was to be able to look anywhere in garage and see what circuit a tool is plugged into so if I want I can be sure I use a different circuit for different tool. I suppose I could just “know” left outlet is one circuit and right outlet is the other, but that concept bothered me more then dual colored outlets. In actuality when u see 18 boxes all setup the same way it starts to look more consistent and less random.
P
pjmariner
Marshfield MA
Its been awhile since I updated, progress slow during son's football season
Here are the outlets on the long miter/work bench wall, the bottom two outlets with coiled wire will be inside the work bench, one for a vacuum, one for a compressor. once bench is mounted I will mount 5 more boxes in the face of the work bench.
44405682322_c13ce9c81a.jpg9ABB65B6-0CFD-4624-B531-07B863101A04 by https://www.flickr.com/photos/120925262@N04/, on Flickr
the back wall is where tool chest etc will go
44405681982_a2cbac0167.jpg6F1B77BB-5A5D-4905-AA34-1F2BAD7CD119 by https://www.flickr.com/photos/120925262@N04/, on Flickr
there is an box in the center of ceiling on both bays of garage, plus one on the support beam in middle of garage
43358094215_36109ea6f0.jpgC0F3D6BF-D929-4709-B422-37BBF27FD171 by https://www.flickr.com/photos/120925262@N04/, on Flickr
43358100405_dc0c557fea.jpgE564736A-CC78-4534-8E07-A2597EB7D400 by https://www.flickr.com/photos/120925262@N04/, on Flickr
Made a spot for my grandfathers 70's classic Zenith "circle of sound" radio, essentially a downward firing 360 degree horn loaded clock radio, easily fills garage with tunes, and it is fully enclosed with no vents, and the with the bottom firing horn speaker is essentially "dust proof" perfect for a woodworking shop.
42646103820_cc39693434.jpgD4F761E9-0BD6-45A0-A826-95A7E6658416 by , on Flickr
Started workbench, ripped down the boards left behind from the storage shelves when I bought the house into 2x4, and setup ledger board around perimeter.
45636236511_66b01bd0bd.jpg83A086C3-34B7-4965-9B2F-11999A993673 by , on Flickr
The front of the work bench is all 5/4 pine. I made them essentially like an oversized face frame. The 5/4 is not much more than dimensional lumber, and tends to be much straighter and easy to work with
44722318495_9cf76f79c7.jpg135F348B-0381-4651-A9D2-0A76D69B7604 by , on Flickr
43818416280_b41572cbcc.jpgAD18B9E1-4D09-4FCA-AB1C-CB884B3611C2 by , on Flickr
More salvaged shelve woods is used for the stringers.
31926399318_507e16a0cc.jpg0638AB5D-598A-4C94-AA98-51B0191B6D12 by , on Flickr
44884663005_00b7612c4a.jpgD7D721AB-2AF2-4EEA-A027-3507242EC746 by , on Flickr
That is where I am at with work bench for now, next step is finish framing, run wire and add outlet boxes to face frames,
add doors/top/miter track/mites saw, etc..... I also have some old kitchen cabinets I will reface/repurpose to match
Other mini project, previous owners left on the storage shelves a rusty Boston L pencil sharpener with missing handle, so I took time for minor resto...
here is catch before the white vinegar dip
45585708552_f74f20ec1e.jpg8EC6A758-335E-4A56-AA54-C325E2D7A031 by , on Flickr
here it is after 2 hours and a rub down with some aluminum foil.
44722312635_c6e84ba178.jpgBF7391A9-B1FF-49B2-BD57-4FC28F593492 by , on Flickr
here it is with a little time at buffing wheel, and an old screw driver handle cut down and reshaped for a new handle
31926395068_cbfea65df7.jpg054522B0-BB3A-4607-99CB-FAE7DD738D57 by , on Flickr
P
pjmariner
Marshfield MA
So I got my Wen air cleaner today, and I came up with a good way to mount it nearly flush to the ceiling, yet still be able to remove it if need be.
I only have 7' ceilings so every inch counts. With the supplied hooks on the ceiling, and hooks on top of the air cleaner, that would put the unit at about 5'10" in my shop, aka too low.
the air cleaner itself is 10" tall, and with this mounting system, mounted it is just over 11" tall, and it is about 6'1" below air cleaner now.
here is how i mounted it using unistrut attached to ceiling and unistrut attached to unit to make a sliding rail.
05CB9108-01B5-40E9-9E56-114D502CDC04 by https://www.flickr.com/photos/120925262@N04/, on Flickr
Here you can see it is tucked over my sewer pipe, and clears by an inch, allowing me to get it as close as possible to my longest back wall. The zip tie goes through a hole in rail attached to ceiling to keep it positioned front to back. i doubt it would move anyway, its a friction fit.
986169D7-B24B-456E-AC53-D63DFD2AFAA5 by https://www.flickr.com/photos/120925262@N04/, on Flickr
Here you can see output is along the long wall, to promote circulation
8BE8C6FA-C078-4329-B026-410840EB7827 by https://www.flickr.com/photos/120925262@N04/, on Flickr
This weekend its back to working on the miter station/workbench
P
pjmariner
Marshfield MA
lots of work happening, I finished wiring all the outlets for the work bench, the long end has three boxes, plus one box in cabinet for vacuum, the short end has two boxes plus one in cabinet for compressor
B90B6281-1A7C-478D-82BC-B84F734505CE by , on Flickr
AB369261-0461-4EB4-8AE2-634F909D65C9 by , on Flickr
I hung and framed wallpeg vinyl pegbopard, then added my tekton metric/SAE wrenches, took a few tries to get the layout right
824B5A1F-D676-429A-9B3B-C22A7DE17A93 by , on Flickr
7BFF4601-4358-4961-BCCD-E152F7FDC455 by , on Flickr
next the bench tops, two layers of mdf, a sheet of hardboard, and maple edge banding, and several coats of wipe on poly, and two coats of the wall color paint on the bench
C3EC2C59-6D8C-44DE-AEC3-BD5BFB5FA62D by , on Flickr
D5BED651-120B-4331-85DE-B549B49D3914 by , on Flickr
next is the cradle for the Bosch glide saw, this things rocks
0297ABA9-1C55-4F28-85EA-A677FA2F9516 by , on Flickr
I unearthed my Morgan 88 from storage, This is what it looks like after I lubed the main screw and gave it several wd40 rubdowns. I got the vise on ebay about a year ago, it had surface rust, but very minor usage. Jaws are like new. I don't plan on doing much else to it but using it and keep it well oiled.
8554BA19-493C-4248-9A19-FB53EE9CBF07 by , on Flickr
This was nerve raking to say the least. Routing 8' foot channel for T-track in fully finished and mounted bench. I also routed a shallow channel for tape measure that my stop block will utilize
7BF63E21-4556-4127-975F-BCBA1B4F5BF3 by , on Flickr
11598426-C075-4596-8E15-535BA5B0B908 by , on Flickr
Here is my stop block solution gleamed from many ideas i have seen, and modified for my purpose. I don't like vertical miter fences because they take up bench space, and when long boards have a bow as most do, they get in way and make keeping board square to miter fence an issue. Also, when this stop block is removed i have a flat, fully usable 8 foot bench, and the track can also be used for hold downs for sanding etc.
The stop block uses a heavy duty 4.5 inch ball bearing hinge so it can flip out of the way when cleaning up edges or making quick rough cross cuts. The tape is a Starrett left reading 12' tape. I also added a Lexan cursor for the tape measure which I scribed and colored with a red sharpie. It is slotted to fine tune the stop block for perfect length cuts. It has a hard maple runner and one bolt for the t-track knob. Now i have it dialed in I can cut any length board up to 9 feet within a 64th of an inch with repeatability. For short cuts I have a 20"spacer block, and use that to cut pieces < 20" perfectly.
105BA8B3-6DE8-4B73-BE16-C9410C55A63C by , on Flickr
25478C3D-2447-47B0-A9F8-7C0A09431D27 by , on Flickr
837082BD-B897-49A1-B1C3-81512D2CF8C4 by , on Flickr
CF893DAF-5328-4D3A-B5DE-CED321FFFF8A by , on Flickr
I used the saw heavily for a day, and while the vacuum and modified dust boot does great job on short cross cuts. On wider boards, or miters, especially when cutting fast I was getting to much dust so i built a dust hood and the difference is night and day. It does cover a fair amount of my pegboard, but I can hang tools from hood too down the road if i see fit. With the hood and the vacuum I get almost zero dust on the bench
DE5BD98D-59B9-4C4F-984A-9BA9D4CD9C19 by , on Flickr
Here you can see the vacuum in the cabinet which i control with a remote, and the duststopper separator under the saw. I have a hose running out to table saw, and a hose for the miter saw, and simply switch them at the separator when needed. The dustopper works very well keeping filter clean and making clean out easy.
636F83B2-C247-4755-AB3A-E7FEAB4E21C4 by , on Flickr
A9FC87E9-BC49-41F2-96EF-1B9BE4845853 by , on Flickr
I almost done with the initial shop build. all that is left is to paint and hang doors for work benches, and renovate, paint and hang old kitchen cabinets that will go above long end of work bench.
bj383ss
TX
Miter saw bench came out great. I see you joined the "dark side" of no miter fence. I like your stop block solution as well. I think you should rename your thread the 4 Gang Outlet Shop. Seriously though I am a little jealous at how many outlets you have.
Bret
