Whats the home wifi/network going to be like? I can see a need for at least 3 APs for coverage.
I have been working a bit on the low voltage network plan, but it is not fully flushed out yet. I need to work out some more details, but it is a good start given how early I am in construction.
The orange triangle represent AP locations. For standard 2.4 and 5GHz 802.11ac operation I suspect I will only need 3 or 4 total APs in the house. Both 2.5 and 5Ghz have good reflection propagation, and since I will probably start with Ubiquity UAP HDs that have MU-MIMO it is easy to measure and adjust coverage as needed. One great thing about the Ubiquity APs is the ability to regulate power so you can form minimal overlap coverage envelopes. I have a couple of tools to help out with this.
The reason for the larger number of AP locations is two fold - The first is to provide options for the initial install, as it is quite difficult to predict RF reflection paths in structure. The second and more important reason is to have eventual support for 802.11ad 60GHz technology. Long term I expect that kind of direct wave near line of sight to be the way things go, especially for >1GBs wireless delivery. In that case it is critical to have AP locations in nearly every room.
Given the low cost of CAT6A wiring, there is no reason not to do it now. Most of the drops in the house will terminate in the dedicated cooled server room on the lower floor, which has its own dedicated battery backed power feed (which is then generator back fed) There will be some point to point CAT6A for HDMI interconnects in a few place, plus fiber from the server room to both the AV area, as well as my office and the driveway. The fiber is primarily to support 10/40/100gig, and in the case of the driveway to support the 1000ft distance. I'll probably use a combination of single mode 9/125 and some multimode OM4, as they are very inexpensive to run and very usable. I expect to have a couple of hundred drops in total including for things like cameras, sensors, and the like. I expect there is be somewhere around 15-20 miles of wire to pull give or take a few miles.
I also have the other usual home automation like stuff.. All UPB switches, Speakers in almost every room, security and presence following systems, plus some cool SDR stuff for ham radio and some LMR-400 to the roof and to the back area for a potential tower.
There are data drops on the diagram, plus cameras, intercom and audio control, and a few ZWave interfaces. At least in the current plan all of the speakers run to the central server room with stops at the wall for control (probably not needed), and each room also has a wall control with Cat6 for audio control interfacing.
You can try to get it right, but there will always be some things we can't predict - to help that I will also run some conduit (not used) for future unplanned wiring needs.
Again, still more need to flush out, and always appreciate suggestions!
Jeff
