JDMjunkies.ch
Ha, that's interesting, Never thought about moss related problemsFantastic progress. It is really cool to follow along on your project while doing a house myself. My wife knows all about your house as I refer to it as the 'awesome swiss house!'. It is surprising how much localization there is in modern construction. Here in the pacific nw you would probably not see many external blind systems due to the significant lack of sunshine, and the persistence availability of moss!
European DIN based cabinets are so interesting compared to the standard american cabinet design. The use of small bus bars to link subcircuits,and the variety of breaker designs is cool. What size is the total cabinet and house capacity (volts and amps)?
Jeff
It's like evolution, every part of the world has evolved certain solutions for certain local-only problems and ended up with houses specific to the local needs. So interesting to see other parts of the world...
Same here, my wife knows youre house as the amazing North american house. I use it as a reference sometimes when we have new ideas again.
I need to check the Overall ratings since i don't know and it's not finnished yet. We have one main cabinet outside with the mains supply connection, which is then splitted to the two houses with each one main cabinet inside each part of the house. We have a second one inside the technical compartment where the whole network and cable-tv/internet setup is, and a third one will follow with the Photovoltaic Frequency converter and stuff.
We run a variety of different voltages, but need to check the amp ratings.
- 380V AC / 3 phase in the workshop for big machinery (standard is 16Amps)
- 240V AC / 1 phase for standard outlets (standard is 10amps)
- 24V DC for most of the BUS systems and integrated LED Lighting
- 24V AC for the garden watering valves (don't ask my why they use AC)
- 12V DC for the stairs lighting, since that was not available in 24V DC
the low voltage wiring is general for low-power rating so i guess the max current is around 1 Amp.
The Photovoltaic system has a DC-Bus of max 16 Amps and max of 0,8KV DC voltage
The mains cabinet is still covered until the insulation work is done at the in-laws house. But i will definitly have a look inside when it's free to access...
or is it because older people use to say the older voltage like 230V and 380V but it is 240V and 400V now?
