txlonghorn1989
- Joined
- Feb 27, 2017
- Messages
- 2,786
Someone a few pages back had thought that the endcap looked like it had been repaired. After looking at your pics again I agree. I think the endcap/nut was pushed out and this bent the pins and broke the endcap.
You need to use a wire wheel with a hand grinder or wire wheel on a bench grinder or just a hand wire brush and cleanup the endcap down to the bare metal inside and out and see what the deal is.
The pins should be knocked out from the inside. The pins could be tapered and if you push them in you can break the end of the vise. Again, clean up the outside of the vise around the pins and look at it for any signs of cracks.
Kevin
I'm giving up now if those bent pins have to be knocked out from the inside! I will post pics when I get the end cap cleaned up. Thanks for the advice Kevin.
All: Can anyone confirm if these pins are tapered and have to be removed inside-out?
I'm gonna move working this to the vise repair thread. Thanks everyone!
