Between 265 & 485 SQ/FT The 12-Gauge Garage
J
Jack Olsen
Los Angeles
Two quick Saturday garage projects. A phone and a clock.
Not too long ago, I installed a phone in my garage that was a reproduction of the old Henry Dreyfuss-designed Western Electric 354. It had touch-tone buttons to replace the dial, but still looked kind of appropriate in a vintage looking garage.
Well, I liked the look of it -- but it kind of bugged me when I learned that I could get an actual Western Electric 354 for about half of what the reproductions sell for. So I picked up one, and was surprised that it fired right up and gave me a dial tone as soon as I wired it to a modern plug. It's kind of strange to dial with the old dial-clicker and not only have it work, but have it connect you to your modern cell phone. Apparently, phone companies are required to support the old dial-type phones. Imagine being able to access the network with your current cell phone in the year 2070. Not only is there no doubt it would have dissolved away to nothing, I'm sure the standards will have changed. But for now, this 1951 phone works just fine. It's amazing to see something built this well.
The phone came with a dial insert with a previous user's phone number in it. I made one for my own number. I learned that the exchange name for my prefix had originally been WEbster.
Next up, the clock. I'm going to move my drill press from the mouth of the garage back to my bench, but doing so will block the view of my clock. And the recent 'shop clock' thread on this board got me thinking about those old two-faced clocks that you'd see in train station and school corridors. So I bought two of the same type of clock and made a bracket to hold them up as one two-faced clock.
Here's the clock I bought -- the frame is red to match my toolboxes.
I cut a very basic bracket out of a piece of aluminum. Here it is on my 'poor man's press brake.'
A little bit of paint and I put it up on the pillar. I like the old-fashioned look of it, and I can see it from either side of the garage -- and also out in the driveway.
BetterDays
Jack,
As always, you work is an inspiration to me.
The little details make the difference.
Fidget
Oregon City
It's always good to have one of the old dial phones around for when the power goes out. I've used Mothers' metal polish on bakelite radios cases to remove the oxidation, and get it's shine back. Been doing that for years. Something to think about if your phone is getting that nasty texture to it.
santagary
Pagosa Springs, Colorado
Wow, your color sense and spatial relations in that space are mind boggling. Did you weld up the bench in front of the garage with that cool arch? I think that bench/table is a piece of art. Do you have any scale drawings/measurements? I'd like to try and make one. You're obviously a writer for sure. Any involvement by your wife in these designs. The arch seems to be a theme in the aforementioned bench/table and your storage shed arched roofs which also match the spanish tile arches...correct, or am I off there? Want a ski week vacation??? You can visit my garage and give me some ideas in [email protected]
J
Jack Olsen
Los Angeles
Thanks very much, guys.
I did make the front table myself. I don't have much in the way of plans, outside of the drawing I made the morning I built it.
Here it is in progress:
I put an arch or a curve in a lot of the stuff I build as a kind of a nod to my father, who helped me with my first big building project as a kid -- a 20' diameter skateboarding half pipe. I was itching to just get it done, and he stood back and let me initially make one that was just awful (I'd eyeballed the curve of the thing). Then he patiently showed me how to do it, and the half pipe was great and stood in our back yard for about a decade. I don't know why I still use that basic principle whenever I can, but I do.
On the clock, I'm still trying to decide if the red is too much. It's one of those doesn't-matter-at-all things that'll percolate in the back of my mind until I make a decision. I could change the red parts of the clock to a gloss gray or even black pretty easily. I could also paint it green to match the cabinets.
I'll see.
Today I shortened the drill press by 3" so it would fit on the main bench, in front of where the old clock used to be.
You can see in this first picture the gap between the ring that marks the top of the adjustment range and the head unit. I knew it would reduce my adjustibility, somewhat, but I decided if I shortened the thing it would fit on my bench and I wouldn't need a dedicated table for it at the front of the garage.
Head removed:
Shortened:
Now it fits:
The garage is a mess, but you get the idea of how it looks in its new location:
Now I'm going to build a shallow (8" deep) storage cabinet to go where the drill press used to sit. This old picture will show what I'm talking about.
J
Jack Olsen
Los Angeles
Well, I made some progress on the shallow plywood cabinet to go along the wall at one end of the steel-and-butcher-block bench.
I wanted a cabinet to store my stepladder and step stool without simply leaning them against the wall. The challenge is that if I want full swing-out doors, I'd have to move the bench a long way from the face of the cabinet. And sliding doors wouldn't give me a wide enough opening to fit the big ladder in.
So I came up with a hinging scheme that has the door fold as it opens. It only needs as much space as the short section of the door for clearance. I used some hinges I had on hand.
In fact, the whole cabinet was made out of stuff I had on hand. The wood is left over from making shelves for one of the steel cabinets.
Here you can see it when it's open.
This is what it looks like when it's closed. This picture shows how close I can have the table and still have plenty of room to move the stepladder in and out of the cabinet.
I still need to install a handle and some of the belt-line aluminum trim to match the rest of the cabinets.
Dan in Pasadena
Pasadena, CA
I like the clock Jack.
It looks great in red, picks up on the color of your tool boxes. At the risk of sounding negative, I think you may be getting a bit too monochromatic with the green. Don't get me wrong, your garage is excellent - who am I to say much since it's been in a magazine. But I really do think just a few more red accents here and there would make it pop a bit more.
J
Jack Olsen
Los Angeles
Too much green?! But I've still got two gallons of the paint! ;)
With the wise counsel of the guys on this board, I let go of the idea of painting the clock green. Instead, I took both faces apart and painted the bezel the same shade of red as the toolboxes. Before, it had been just a shade different than the other reds.
I also picked up a second-hand Dazor magnifying lamp. It came with a rolling floor base, which I don't need. My first thought was to drill a hole in one of my benches for it, but then I started wondering which bench -- and that made me dig out an old angle plate. I put it on the drill press and cut a 1/2" hole in it, painted it, then put some foot pads on. The result isn't pretty, but it's not going to move unless I pick it up and move it.
While I was on a roll, I added the aluminum trim and handle to the ladder closet. Still have to sand/scuff the trim, but you get the idea.
Now I've got to clean the place up. There's sawdust everywhere from building that cabinet.
I promise: no more green for a while. :)
Dan in Pasadena
Pasadena, CA
Looks great. I like the magnifying lamp. My HF one is plain white... I haven't done a coordinated paint scheme yet & don't I have multiple work surfaces, yet. BTW, I like the angle base you adapted; sorta came out "portably-permanent"?
I laughed out loud about two more gal's of green paint! I've got SO much left over paint! I've decided to "pull a Jack Olsen" and try to make maximum use of stuff I already have. All the latex whites are going to be mixed together to freshen up my pegboard (Where the HECK did you buy the Stay-Put pegboard clips?). The lower walls of my garage will be a machine gray and a sort of 70's Harvest Gold is going on my cabinets because my tall lateral cabinet is already that color and needs freshening.
I'm hoping mine will have your vintage look since as my garage is as old (older?) than yours. Your incandescent spot lights are warmer and highlight areas beter than my fluorescents - I may have to add some clamp lights. My floor is a serious mess. So much so that I doubt I could use tile but I'd love to. I may demo out sections, re-pour and just use as-is. No perimeter footing, its all one slab so I can't just demo and replace - damn! Anyway, yours is still the gold standard for ordinary suburban-sized, older garages, I think.
Brian R
Chestertown, MD
Can't decide which I like better - the car or the garage.
In the end the green paint and all those work spaces win out - the garage.
Well done.
Po'Boy
Really great space, I must say. I read through the thread, and not sure if I missed it, but where did you get those hanging lights from??
santagary
Your garage is now my computer wallpaper...I can't quit looking at it...it's inspired...or you are or something. I also drive a Porsche, a 2001 boxter, tiptronic. I guess I'm trying too hard too at 68. It's more fun than my airplane. I'm most inspired by your "out of sight" approach from the front/outside of the garage. Your way of storing and hiding clutter is amazing. My offer of a vacation week in Colorado still stands and you can show me how to drive the Boxter properly. g
kizer
Marysville, North of Seattle WA
Hey cogrates on the magazine article. I picked one up the day before yesterday and sure enough theres Jacks garage in it. I think it was garage makeover or something like that.
I had to buy it because I'm adicted to garages for some odd reason. ;)
Lightfighter
Milwaukee, WI
Jack,
Congratulations! In my opinion, you have one of the best garages on this site. It, by far, sets the standard for organization, practical usage, and innovative ideas. I am inspired by your willingness to continually tweak it to suit your needs. It is truly a nice space to "rest" your Porsche. I feel like they compliment one another. Keep up the good work!
J
Jack Olsen
Los Angeles
Wow, Gary. Again, that's very generous. Thanks again. The Boxster is a really great little Porsche -- totally underrated in my opinion.
And since you've put a picture of my garage on your computer, here are some more I took today. The sawdust is cleaned up and the clock is starting to grow on me.
With the car:
Without the car:
View from the back steps:
And one more:
It's not quite as minimalist as it was before the extra saw and the magnifying lamp went on the middle bench. But it's still pretty clean.
And thanks to you guys too, Kizer and Lightfighter.
J
Jack Olsen
Los Angeles
Now here's the deal: as of today, my wife and son are out of town for four days, visiting family while I'm here alone with a work project -- and the garage. Today I swept it out and took a bunch of pictures. Then I figured out how to sandwich them together into a little video slideshow. So, if you're interested in a kind of 'walk around' of the place, this is it.
I can hear my wife now. 'A video? Seriously? About the garage?'
Like I said -- she's out of town, so no one could tell me to stop. :)
HERE'S THE LINK. If it works, let me know.
Dan in Pasadena
Pasadena, CA
I agree, well done. The funky old bluesy music is right on the money.
I keep getting little ideas from you. I have my old (but precious to me) Pioneer component system in my garage that I worry about dust getting into. I never thought of putting it in one of my cabinets; now I do! Where are your speakers? The ones that came with my stereo are HUGE by today's standards. Thought of mounting them way up high, kinda pointing downward but... I keep watching CL for somewhat smaller ones.
EDIT: P.S. We need new exterior shots when the ivy leafs out to match the old ones.
markviii
east central IL
Jack,
The YouTube video is wonderful! And the blues background is just our style. In our opinion, you can't have a garage without tunes (and the more blues the better). (we've got many blues and rock-and-roll recordings on vinyl from the earliest recordings on - there wouldn't be Rock-n-Roll without the Blues)
Also, I love the double-hinged cabinet - an elegant solution!
Chris
mdbeck1
Norman, OK
Okay, I may have missed it but it looks like you are using some kind of pickup receiver hitch to mount tools onto the front your workbench (vice and/or bench grinder and/or ???).
1. Please show some more details on how you attached the tools to be removable.
2. Please show some details on how the receivers are attached to the bench.
3. Does this configuration work well for you?
4. Is the bench mounted to the wall?
Po'Boy
On the cabinets you built that has the curved contour on the one end, what materials did you use to build it, how did you attatch said materials to each other?
It looks like 1/2" plywood, and 1'x2's. I remember you said you attatched it to the wall studs and ceiling joists, I assume via the plywood backing, and top of the cabinets. Apprx. how much weight is in those cabinets? I'm looking at building some in a similar fashion. Thanks.
Matt
santagary
Wow I wish I knew how to make a slide/video like that...I'd tour you guys through my ranch/barn/shop/with mountain scenery. Great job Jack. I drove a lot of 911's before I found this Boxter with 30000 miles, I'll send a pic when I figure out how to attach it, etc. I'm a little challenged when it comes to computer/tech stuff. I'm changing my wallpaper to your newest shot with the Porsche.
J
Jack Olsen
Los Angeles
In fact, I think there should be a thread with GJ video tours. I'm in, who else?
Yours would be a great subject. I was turning around trying to think 'what else can I snap a picture of?' because my place is pretty small. Your barn has a whole story to it.
I've got one speaker above the man door, and one in the opposite corner. I put a text label in the video where the one in the corner shows up in the Youtube slide show.
Jack,
Chris
Now, you and your husband's place would make a great documentary -- not just a slideshow. You should get a cinema studies major from Champaign (I was one there for two years, back in the eighties) to come out and document everything, working in those old pictures. I don't know about commercial prospects, but it would be a huge hit with this crowd on Youtube. You've got the extra time for that, right? ;)
They're double hitch mounts I got on sale at Harbor Freight. I bolted them to the wood bench, and yes, the bench is held to the wall with lag bolts. I picked up some $3 bolts to tighten stuff to them with a welded on nut.
It looks like 1/2" plywood, and 1'x2's. I remember you said you attatched it to the wall studs and ceiling joists, I assume via the plywood backing, and top of the cabinets. Apprx. how much weight is in those cabinets? I'm looking at building some in a similar fashion. t
I used a sheet of thin paneling -- some sort of particle-board based stuff, for the face itself. I needed something that would follow the contour and I grabbed whatever looked best at Home Depot. The rest is 1x2s and 2x4s and some more flat sheets of cheap hardboard. I didn't build full boxes, just a face (hanging from the ceiling joists) and a main shelf (attached to the wall studs. For the curved part, I used 1x2 studs sandwiched between two pieces of plywood/OSB that I cut the curve into with a jigsaw. It's pretty basic. For the sliding doors, I used a table saw to cut grooves in a 2x4 to make tracks for the doors. I was learning as I went on those, but knew that they weren't going to see a lot of use -- just long term storage for stuff. They hold a fair amount of weight -- anything I've been able to lift that high has gone in without an issue.
The best soffits to copy (in my opinon) are XcYZ's, from this thread. He really puts mine to shame. (Plus, he's got an awesome Camaro.)
But if you're set on seeing mine as they went together, they're here.
Thanks. I'd explain how I did it, but I'm on a Mac -- where they make this kind of stuff so easy that even I can do it.
Dan in Pasadena
Pasadena, CA
...In fact, I think there should be a thread with GJ video tours. I'm in, who else?
THis is an EXCELLENT idea, particularly the guys whose garages made it into the magazine....and Nimrod's. I'm still annoyed his wasn't included in that mag and no one else seemed to notice.
P.S. I have a video camera, but I haven't the foggiest idea how one would go about uploading a video here!:headscrat
santagary
I found your tile today for 57 cents...boxes and boxes of it at Home Depot...boy, I'm tempted but worried about freezing winter conditions here for 5 months a year. Whaddya think?
J
Jack Olsen
Los Angeles
That price would have saved me fifty bucks.
Here's the full data on the tiles.
Tiles come with three ratings from the manufacturer.
First off, there's a P.E.I. (Porcelain Enamel Institute) Wear Rating:
Group I - Tiles suitable only for residential/commercial walls. Not suitable and/or recommended for foot traffic
Group II - Tiles suited to general light residential traffic, except kitchens, entrance halls, and other areas subjected to continuous foot traffic.
Group III - Tiles suited for all residential and light commercial areas such as offices, reception areas and boutiques.
Group IV - Tiles suited for residential, medium commercial and light institutional applications such as restaurants, hotels, hospital lobbies and corridors.
Group V - Tiles suitable for heavy traffic both residential and heavy commercial applications such airports, malls and subways.
Then there's a Water Absorption Rating:
1. Non-vitreous Tiles - absorb 7% or more of its body weight in water. They are suited for indoor use only and considered to be non-frost resistant.
2. Semi-vitreous Tiles - absorb between 3% to 7% of its body weight in water. They are suited for indoor use only and considered to be non-frost resistant.
3. Vitreous Tiles - absorb between 0.5% to 3% of its body weight in water. They are suited for both interior and exterior applications (covered and/or non-heated rooms not exposed to standing water) and considered to be frost resistant.
4. Impervious Tiles - are the strongest. They absorb between 0 and 0.5% of their weight in water.
Finally, there's COF (coefficient of friction), with a rating for both wet and dry. This is how slippery the tile gets when it's wet. I don't know what the typical range is for ceramic tiles.
My cheapo tiles have a PEI rating of 'IV' (residential, medium commercial and light institutional applications). Obviously, 'V' would be the absolute ideal for a garage.
My water absorption rate is 3-7%, which means the tiles are not frost-resistant or frost-proof, and wouldn't cut it in an exterior application in a part of the country with sub-freezing temps. But then, I would guess Home Depot probably sells more appropriate tiles in parts of the country where it does freeze.
My coefficient of friction is 0.60, wet or dry. I haven't found much on the internet on this, aside from the fact the City of Los Angeles building code requires that level surfaces have a COF of not less than 0.60 and ramps no less than 0.80 when tested. I guess that would mean I'm just slip-resistant enough to be used in the local shopping mall.
So if yours are rated the same as mine, they wouldn't be good for an exterior application in freezing. Does your shop/garage floor get below freezing? It's one thing for the air in there to be freezing, but the ground temperature usually lags behind that.
I'll say this, the installation is not easy work. Mine weighed close to a thousand pounds (which wasn't easy on the Jeep). Setting the tiles is time-consuming; grouting is plain ol' hard labor.
santagary
Thanks for the analysis Jack. I think I'll try a box of the tiles in an out of the way place in my garage where the slab freezes and see what happens next winter, then make the call. We had 60 days below zero this winter and 100 below 15 degrees...snowmobiling, skiing and snowblowing were great fun though (a Kubota 3030 with heated cab and two stage snow blower helps). g
mdbeck1
Norman, OK
Thanks. That clears it up. I noticed that HF also has a single hitch mount with a plate on it for a vice. However the double system would be much more stable. Thanks for the idea.
chrislehr
Portland, OR
Jack,
Still would really like to see a pic of the garage driveway storage opened or your design if you did one - its exactly what I want to do :)
J
Jack Olsen
Los Angeles
The gilding of the proverbial lily continues. ;)
I've never been one for corporate logos or other kinds of automobilia (is that the word?) in my garage, but I picked up a Porsche crest and put it where the old sign from the writer's strike used to be. The union sign was up primarily because I first cleaned up the garage while I was walking a picket line every morning during our hundred-day strike. But I suppose politics and garages are an odd fit.
So here's the new addition:
It's a weird little sign -- not a reproduction or even an attempt at something vintage. It's made of layers of cut plastic.
Also, I picked up the mystery vise I got on ebay for 99 cents. I can't find any manufacturing marks on it, other than a V86 on one jaw and a V87 on the other. That isn't to say there never were marks on it -- but as you can see, the thing's led a pretty hard life.
Anybody recognize it at all? It appears to be pretty well put together, but I'm no vise expert.
Dan in Pasadena
Pasadena, CA
Hi Jack. How will you restore the vice? For 99 cents you could hardly go wrong. Just wire wheel it and spray paint? Or will you take it somehwhere to be media blasted?
I'm cheap AND poor (my daughter's getting married in May!) so I'd probably just clean it up and rattle can it.
