Found a Reed 204 1/2 on craigslist recently. This is how i found it in the wild.
The first thing I noticed after bringing it home was that the main fastener on the bottom is not the typical style that I see online for Reeds (they seem to usually have a round with a large slot). This 204 1/2 has a hex head fastener (similar to my Parker 205) but larger. I used a 1 3/4" socket on it. The second thing I noticed was that this fastener did not want to give up. I used anti-rust soak, heat, and vibration before it eventually succumbed to my 18" breaker bar (with cheater bar attached). This effort bent the metal table that the vise was clamped to at the time. (!)
For the Reed experts, is this a replacement added by a former owner? I think this vise is fairly old (see below) so maybe they used different fasteners back then?
Age? I was worried I wouldn't be able to find any production markings. But after some basic cleaning, I found some markings on the passenger side of the dynamic.
I see a "515" in the red box. My understanding is that this would make this vise a May 1915 production. The 3 patent dates on the static are from 1908, 1912, and 1914 (so that shouldn't preclude May 1915). Any Reed experts know if they updated their casting the very next year after the 1914 patent(s)? Assuming this is correct, I acquired and started working on this vise when it was exactly 105 years old. Seems really cool to me.
One more question for the Reed experts, even after removing the main fastener on the bottom of the base, I can't get the swivel fastener (see last picture) to budge. Are there any good tricks to loosen a frozen swivel base lever/fastener?
Since no one has answered you here, although they did on FB...
yes is 5/15 date. Congrats on the 105 year old score.
The swivel bolt you see with the slot are for the later style R series.. That is the correct swivel bolt for your vise. all the pre R models used a hex bolt.. The slotted bolt didn't start until about 1942.
Any tricks to loosen the swivel lock? sure. hit it with your purse. Seriously. dead blow, lead hammer, etc. A good whack should get it moving.
lucasd2002, I would use heat, it will swell the swivel body and break the rust and will make it easier to remove, you do not want to bend the handle.
My Bison 125 powder coated to match other stuff.
I just finished this one tonight. A late model Yost 32C that came to me with splotchy damaged blue paint and the usual brown staining on the handles, nose and slide. But the jaws looked like new under the greasy dirt.
4 1/2 inch wide jaws.
I’m not crazy about the econo pinched ends on the handles, but that’s how Yost did it.
Thanks!Nicely done Tony! That's a beautiful vise, and it's a nice mix of patina and fresh.![]()
Rustoleum Hammered Verde Green over gray primer. Fluid Film on the bare parts.
Is it possible to buy an ACME long nut? I could weld one up then.
1320
Wow...74 bucks for a vise nut.
I suppose you could just buy it, try it, and return it if it didn’t fit.
I’ve never found a vise with a worn out nut. Would that be from a total lack of lubrication and a determined user (not you of course) continuing to force it open and closed hundreds of times without addressing the problem so easily remedied?
I’m sure I’m preaching to the choir here on the vise pages, but it seems to me anybody using a vise realizes that difficult operation means you probably need some grease somewhere. How long would it take to apply? One minute? Any grease will do. Even WD40 is better than nothing. Vaseline? Used motor oil? Sure!
(Rant over)
