danielbuck
- Joined
- Apr 15, 2014
- Messages
- 921
I'm pretty sure my compressor pump is shot. I have been using it way more than normal over the past few months (since I've been home, and have been working on a lot of projects). Sometimes running almost continuously for hours.
Well, all of a sudden it seemed to not be increasing the pressure very much, it sounds different (higher pitched), and the oil in the sight glass is black (previously it was clear). I've had it for about 8 years now, and regularly change the oil.
I'm going to take it off and eventually try to rebuild it, but in the mean time I need a replacement.
I'm tempted to replace the compressor pump with a dual stage, instead of a single stage. Any reason NOT do do this?
Recommendations for a replacement pump?
It's an "Industrial Air" 60 gallon model. Here's the specs:
https://www.amazon.com/gp/product/B002MKP5K6/?tag=atomicindus08-20
Tank Size: 60 gallon ASME*
Maximum Pressure: 155 psi
cfm at 40 psi: 13.4
cfm at 90 psi: 11.5
Voltage: 208-240 volts
Running hoursepower: 3.7
cfm at 40 psi: 13.4
cfm at 90 psi: 11.5
