I hope that all thread is NOT plated. Electrolysis is a nice clean non toxic solution IF you keep all plating and heavy metals out of the soup. Don't use copper wire, use rebar tie wire (cheap - a couple of bucks a roll in the rebar section of any BB store) use rebar or other plain steel/iron for the anode. Stay away from stainless (some stainless WILL work but its not known (to me) which is safe. - Look up hexavalent chromium...) Graphite works well as an anode.
Too large an anode can load up the power source and burn it up. A guy I know is successfully using a PC power supply (for both an E-tank and nickle plating) and once he got the anode size/mass down, stopped burning them up
