Bighead38
Just got mine. It did not come with any case, just cardboard box.
So you bought the bare tool. It the set?
For that use, Mid Torque should be all you need...
https://www.cpomilwaukee.com/milwau...MIh6zT0pHN6wIVAeazCh2r8QZdEAYYAiABEgLMj_D_BwE
I need your opinions guys. I was borrowing an air impact gun from one of my friends for the last couple of years. I had to give it back to him. The only thing I used it for was changing my wheels from my winter to summer wheels and back again. What would you guys recommend from the Milwaukee line. I have a drill combo right now so i would like to stay with Milwaukee. What can I use for the garage once in a while that will have the power for that and for other tasks?
Anyone get an M12 Hatchet yet? Looks like it would come in handy.
Mine was supposed to be here tomorrow, but looks like shipping got delayed. This will be of TREMENDOUS use in bucking a tree that fell on my property. I’ve been using my hackzall to trim the branches before bucking the trunk with the M18 chainsaw, but having a small handheld chainsaw will make everything go much, much faster.
So I don't know why I ordered it.
RSSWell, I ordered the M12 3/8" Ratchet Auto Kit [ Item# 56401 @ Northern Tool ], the other day during their 1-day 'Flash Sale' on it, and even though I got $51 off, instead of their advertised $31 off..... I've had buyer's remorse ever since I clicked on 'place order' !:~\
Cuz for my DIY use, I just don't know if I'll be using it enough to justify the cost.So I don't know why I ordered it.
Except to fulfill the urge. The urge to splurge !![]()
The first time you use it to run a long bolt in or out in an area with limited swing room, your buyer's remorse will dissappearit quickly became one of my favorite tools and I'm a DIYer as well
Just invent reasons to use it. If you use it enough times you will feel good about the purchase... unless you end up hating it. But you will probably like it.
Thanks for all the upbeat ^ upwords of encouragement !I reach for my M12 3/8" ratchet more often then I do my SO Dual 80's. I bought it to do a TB/WB service on my vehicle, and it paid for itself on that job alone. I really like it when the long extension is on and the bolt is hard to reach.
"---and on top of that...he removes the brake vacuum booster !); neither of which I plan on doing.
Can't find 'en anywhere. Thanks for all the upbeat ^ upwords of encouragement !
I've been putting off changing plugs on our Dodge Ram 1500 after a Dodge mechanic showed & told me how tough they are to get to, (he actually lets all the air out of the front tires---btw, one Monday morn whilst I was at the dealer for service, the Mech had left a customer's front tires completely flat & squished by the heavy front end of the Dodge Ram & wheel rims one entire weekend; I asked the Mech why the tires were flat, and inquired as to whether or not that could damage the tires...to which he said, "Meh"---and on top of that...he removes the brake vacuum booster !); neither of which I plan on doing.
So maybe the M12 will help inspire me to get off my **** and do what needs to be done; I bought the plugs over a year ago ! Lately I've been blaming the delay on not being able to find the two fender protectors I bought the same day at HF.Can't find 'en anywhere.
But seriously.... I blame the purchase on GJ, this thread, and all you addict fellas !!!![]()
Anyone on here got the M12 Rocket worklight? Save your cash. I don't say this often about Milwaukee, but that's one tool I was not impressed with. Not much light output. Mine's going back for a refund.
I was doing some metal fab today which required pilot holes. I currently have a larger M18 drill w/ 5.0 battery, and was thinking it would be nice not to have two drills. One for pilot holes and one for finished hole sizes so i dont have to keep switching drill bits. Thinking a little M12 drill might be the ticket.
I do this a lot and keep thinking the same thing to myself. A little M12 that I can keep a pilot bit in.
Very cool.My 1/2" stubby got a workout today. It powers my tractor lift... It yanked my blade bolts... it helped reattach my deck belt (with the aid of a spoon tire iron too)
Believe it or not... the Tractor Lift uses a 3/8" square drive... I have to use an adapter.
For the record... YES I attached the safety belts and put double tire chucks (front and back of rear tires) Before I even bent down to work on the tractor.
Very cool.Nice pic.
Methinks I should look into getting one of those! It takes me a half hour to get our John Deere GT225 mowing deck unhooked/unlodged then dragged out, rolled out to drive and flipped over.
What's the brand? And any suggestions on suppliers? Thx
I can tell you the impact will ruin the threads if they're acme.
I used mine on a scissor jack and after a few cycles the jack threads seized.
Thanks very much for info & tip; will look it up.I found it on Amazon --- AMAZON LINK HERE --- Price is virtually the same... i bought mine 5 years ago.
In the picture... the tractor is lifted to the FIRST safety height... that yellow handle thing... it can go two more steps up which literally means... you can sit on your **** on the ground and noodle the blades...
It comes with a handle to spin the screw... I rather use Milwaukee Technology... because I can.
READ THE DIRECTIONS when you get it... that safety thing is a ***** if you forget about it when you try to lower the thing... you have to relift it... till the safety releases etc... I ALWAYS forget since mine is "Powered"... <big grin>
Impacts are known to destroy threads on lifting/compressing equipment. If you are going to use an impact on it, you should most certainly use grease of some type or use anti-seize on the threads to prevent galling/damage.
The new M12 installer drill with the interchangeable heads is pretty sweet.
When i hear the idiots putting their stabs down on their campers with a loud mf'ing impact a little part of me hopes is galls up 95% of the way down.
I'm sure you sleep better knowing you didn't help and instead wished ill of them. I would not have known about it if somebody SMART didn't tell me. Take the advice... help others... you wont look so bad in the end.
It was more of a dig on them using a loud a$$ tool at the campground, and not about me not helping someone. If they think its appropriate to use something that loud camping when they pull into their site at 11:30pm, then whom am I to interfere with their fun.
As an engineer/ carpenter/ overall curious George that I constantly find that i have to restrain myself from offering advice. Lots of people just don't care, and I assume that because I am good at being an engineer iI am lacking in the communication dept! Haha
OK, great. Let us know how well it works when you get it!!
So I got to spend about 3 hours with the M12 Hatchet today - long story short... I LOVE it.
I was able to buck a smaller tree that fell on my property using only this tool, with the exception of the last cut which required the M18 chainsaw. This little thing punches way above its weight - I pushed it hard and was only able to stall it once, and that was cutting a 6” limb that I had no business using this tool for. Having said that, I was able to complete that cut! It’s obvious the lawyers wrote the 3” cutting spec for this saw - it will blow through anything 4-5” with no problem.
One thing I don’t love about it is the position of the lock release - it seems to be set a little high for my little girly hands, so sometimes I had to stretch my thumb a bit to actuate the lock release and operate the saw. This is one area where having a slimmer handle would have been nice, but it’s not that big of a deal.
I went through a 6.0 battery and a 4.0 using it for almost two hours of near constant use, so not out of line with what I expected.
All in all, I’m blown away with how fast I was able to work having a one-handed chainsaw at my disposal. My wife came out to check a few hours later and couldn’t believe the fallen tree was already gone. I was very much looking forward to this little saw and Milwaukee did not disappoint. [emoji106][emoji106] from me.
One of my coworkers wore me down enough to get it, should have listened to him earlier as I love it. Shines for tight quarters, where control is more important than pure power and made installing a bunch of cabinet drawer pulls more enjoyable(and faster).That M12 installer drill looked like a spin off of Black and Decker's inception of multi attachment drills![]()
Glad you like the Hatchet. I'm not quite sure who the target buyer is for this tool though.
