TailGunner3000
Hi all. Does anybody know of a source for a replacement chrome style Snap-on decal for a 1750 vise? Thanks.
Like this one? expensive though.Hi all. Does anybody know of a source for a replacement chrome style Snap-on decal for a 1750 vise? Thanks.
And which swivel base will fit this vise? Anyone know?
I have one just like this, it was designed to bolt directly onto a workbench, not a swivel. Actually, I like it that way - lots more stable.
I'm not sure where you can get a horseshoe for it, but you could probably fab one up.
I appreciate the help. Unfortunately I reached out to Snap-on already. They directed me to Wilton, who said they no longer produce that item and have none in back stock.Do not buy that one for $45. Call Snap-On. They directed me where to get two for the S.O. 1750 that I restored, and it sure didn't cost any $45.
I saw the one on ebay. I already decided that was too high a price, especially since I only paid $75 for the vise.
The search continues...
Thanks, but out of stock at both places.I might be able to help. I got Wilton part number 9141401 for my 1765 recently. I got it from tool parts direct but I believe wilton also has it in stock.
I'm still trying to find the U-shaped washer & 3 machine screws for the 3" Wilton. Will one from a newer Wilton 300S (3 inch wide jaws) work? Anyone know?
Appreciated.Tailgunner, these decals seem pretty close:
https://www.ebay.com/itm/Snapon-tools-official-foil-snapon-logo-decal-sticker-new/164295338477?hash=item2640c3e9ed:g:2~gAAOSwQcJfElbb
Altrego — Try a hardware store. I've seen E-clips at my local Ace Hardware. But that can't be the only local source — HD, Lowes...
Just picked up this Reed 204 1/2 R.
Is there a way to get the handle nearly perfectly straight?
But I put it together longways forward so there were more threads available when the jaw was extended.I'm curious what others have done here too.
Here's the swivel plate lock nut from the Columbian 804 that I'm restoring. Might just cut and replace this one...
Overall, it seems to be in very good condition.
Is there a way to get the handle nearly perfectly straight? in the past, I've just heated, hammered, and squeezed in a vise, but I've not been perfectly happy with the results.
Take the whole main screw out, place on 2 anvils of equal height or 2 pieces of large flat iron or the like.---Bridge the gap between the two with the bend in the handle facing upward and strike/ping gently with a 2 or 4 pound sledge and check frequently with some kind of straight edge like a ruler or the like until you are satisfied that it is as straight as it can be or good enough you can live with it.
PS.---Place a piece of wood on the handle like a small board and strike the board so as not to mar the metal.
Thanks. I'll give it a try.Just picked up this Reed 204 1/2 R.
Sent from my Pixel 3a using Tapatalk
Smitty just posted his "Anvil" for such work on the "Vises" thread. a Cummings Diesel wrist pin!
This is a design issue with Wilton vises. The tapered pin needs to be pushed out, not in, and the non-aligned holes makes pushing it straight across impossible. There are several posts with people having the same problem. As I remember it, an appropriately sized allen wrench was the best solution suggested on here.Hey all! I'm working on restoring a Wilton A9450 vice that was abandoned on a military base in southeast Asia. It was getting thrown away, and I received permission by the owning organization to acquire it.
It was rusted so badly, that I had to use a six foot cheater pipe to have enough leverage to unscrew the four mount bolts! Interestingly, this vice had a carcinogenic, hexavalent chromium-containing primer+black topcoat paint job (this primer and paint is normally used on military aircraft, so I assume it was a paint job done by one of the paint shops on the military base). I had to wear an N95 respirator and use a well-ventilated work area in order to sandblast the paint and rust off.
Anyway, the vice has been mostly disassembled, with the exception of a single end cap retaining pin. I was able to remove the first pin by drilling and tapping an M4 thread, and prying the pin out with a pair of flat head screw drivers.
The other pin, however, is much harder to clearly identify, likely due to a combination of the heavy rust and subsequent sandblasting. I don't want to use the same removal method, for fear of accidentally drilling into the vise body.
If you look closely, you can make out the outline of the bottom portion of the pin, and right above that, you can see an indentation where I was attempting to punch out the pin. But, she won't budge.
Here's the REAL fun part though:looking from the other side, you can see that the pins do not line up! see that little shiny bit in the hole? That is the edge of the other pin just barely visible, slightly overlapping with the hole from the first pin that I removed. I tried using a slightly bent nail to punch it out from the inside, but I was worried about accidentally peening the pin in place from the inside, so I stopped that approach almost immediately. Any thoughts?![]()
I am considering taking it to a professional machinist at this point. The only other idea I had was to use some kind of physical or chemical process that would allow me to easily see the pin in contrast from the vise body, since I am pretty sure the pins are steel, while the body is cast iron, no? Thank you all in advance!
Skydronaut, please post some pictures of the Wilton so we can all drool.
