Three most used tools
fao110
The three tools I use the most.
Laptop computer with troubleshooting and programming software for electric vehicles,
Multimeter
Battery load tester
What’s the tools you use the most?
mazdeuce
Texas
8,10,12,14,17,19 combination wrenches
Safety wire pliers
Tire levers
I ride/race Honda motorcycles.
didit
S.W. Ontario
The MIG welder, angle grinder and air compressor are used daily and if they are being used they are being complimented by hundreds of others as well. It normally takes me at least a half hour to return every thing where it goes after a days work in the garage.
xela456
12" Knipex cobras
8" Irega wide mouth adjustable wrench
1-1/2" Red devil hard putty knife sharpened to a razor.
Honorable mention is my Klein Linemans.
I'm a Millwright contractor currently residing at a cement plant.
protegeV
DFW
3/8 stubby impact
1/4 impact driver
3/8 drive 13mm impact swivel
xjfish
Swivel Impact sockets
PC with Alldata and Idenifix
1/4" tools
? really varies from day to day for me.
ssdave
Eastern Oregon
Tape measure, pocket knife, Snap-on ratcheting screwdriver with about 120 different bits, in a MAC case.
Followed closely by SO Talon needlenose pliers.
SuperCat
Sacramento, CA
Seems like every job requires these items:
#2 Philips screwdriver
3/8 drive ratchet and metric socket set
Astro 30SL Flexible Rechargeable COB LED Slim Light
Honorable mention: razor blade, tape measure, pencil, pliers, wire cutters, Ryobi 18V drill & accessories, Amazon, Autozone, Ace Hardware, Home Depot, hammer, bigger hammer when irritated, and last but not least: a box of Band-Aid bandages. Oh, yes, and a shovel for things that need to be buried next to Jimmy Hoffa so they never see the light of day again. :thumbup:
bargainhuntingking
The Amazing Pacific Northwest
Samuel Hearne explored overland passages for 32 months in the late 1700s from Hudson Bay to the Arctic Ocean with First Nations people in the area (Cree, Chipewyan, Dog Rib).
Hearne found that the 4 most important tools of these people to survive in this austere and demanding environment, and the only tools needed to build a canoe, were a knife, a hatchet, a file and an awl.
Chucktin
Seems like I can't do anything without pulling out most of the tools I have. Doesn't matter if it's an electric repair, a car job, carpentry or fencing.
And if I don't (re)organize them when I'm done I'll be at sea next time till I find that -$(86@ #2 phillips.
My simple (minded) solution has been to eventually buy 2x or even 3x of everything. And then there's wifie who needs her own or she raids mine.
PS HF is a godsend!
Sent from my Pixel 4a using Tapatalk
MushCreek
Upstate South Carolina
Hammer
Bigger hammer
Sledge hammer
(credit card)
Seriously, it's hard to answer, as I do so many different types of projects. I guess the 1/4" M18 driver comes out the most, along with a tape measure and a speed square. Of course, I would use none of those to tackle plumbing, or electrical, or automotive, or yard work, or...
pizza
Midwest, USA
for what job? lol
i use these many times each day:
  1. computer
  2. smart phone
  3. flashlight (zebralight SC64w HI)
credit card and car are also frequently used.
FuzzyTiger
Canada
I feel like you're all forgetting the trusty old flat head screw driver. The single most useless screwdriver and yet somehow most useful tool at the same time. Is there a job where you don't need to poke, prod or pry at something?
After that is Google which lets me access the sum of all human knowledge and stupidity at the same time with no distinction made between them.
Finally a light because there's never enough light when and where you need it.
bwringer
Indianapolis
A few weeks ago, I used a flat head screwdriver to tighten and replace some screws in an old piece of furniture.
It felt kinda weird to abuse my pry bars that way. :D
Mostly Japanese brand motorcycle work here, and our cars are Toy Yodas.
1) Light. I have an assortment, but the most-used is one of those Harbor Freight rechargeable folding stick dealios. I have two of these, actually.
2) Harbor Freight 1/4" drive roto ratchet with a 10mm deep socket. I never even bother to put the socket back on the rail. I have at least four of these 1/4" drive roto rats around. They're insanely useful. Usually one gets an 8mm and another gets a 12mm for the duration of whatever I'm doing, but the 10mm pretty much remains permanently mounted.
3) If you count my air compressor and motorcycle lift table as "shop equipment" and not tools, then third place might go to one of several pairs of Hakko flush cutters. I seem to need these for cutting a wire or cable tie several times for each project. I keep several pairs around so they're always handy. I also consider them a consumable; eventually the edges deteriorate so they won't cut cleanly, so I have to say goodbye. A box of five pairs on Amazon is quite cheap for the quality you get.
ssdave
Eastern Oregon
I know the feeling. I grabbed a big Snap-on flat driver the other day, because I had some large flat head screws that were very tight. Put a wrench on the hex bolster on the driver, and twisted the tip off. I've pried on I don't know how many things with that driver, I've had that set for 15 years or so, and they're well worn. Then, a simple screw removal breaks it!
XJSuperman
Central Iowa
Recently?
Angle grinder
Hammer
welder
A tape measure, wirebrush, die grinder, a couple wrenches, and more aren't far behind though.
speed bump
Butte Montana
By far would be Leatherman, 10 ft tape, and streamlight. Honorable mentions are phone camera, 6" caliper, and a 8" crescent hammer.
Fedwrench
Valley of the sun
Most used tool, Alexander made pocket screwdriver with magnet on handle. Opening parts boxes, connectors, trim panels, retrieving something dropped. It does everything but, screw screws. :lol:
Second most used tool, a computer with manufacturer's service information. I might fix more vehicles with a laptop than regular tools at times.
Third most used tool, a pocket flashlight coast or streamlight. I'm old so, I need something bright. :beer:
4 FN 27
Minnesnowta
Brain, Left Hand and Right Hand. In that order.
Or
Computer (Solidworks/Cadkey), Water Jet, Press Brake
Or
3/8 Drive Craftsman Professional Long Handle Ratchet, 9/16 Reversible Ratchet Wrench, 3/8 Drive Dewalt Cordless Impact
