Koken adapter and ktc socket but needs the plastic....
Nice. One of the Japanese tool review youtubers I saw had wrapped plastic tape on the end of his impact socket in lieu of the plastic sleeve from the manufacturer.
A few pages back I mentioned that I'd picked up my first Ko-ken ZEAL ratchet (the basic 3725Z.)
One of the things that always kept me from buying one was the polymer handle. I've never really liked those, as I think it makes the ratchets look a little cheesy. I would much prefer knurling. But, since that's the only way Ko-ken makes the ZEAL ratchets, I didn't have much of a choice.
Fast-forward to now: in the last couple of weeks I've been working on my wife's car. Our garage is unheated, and it's winter. The all-metal handles of my other ratchets (Wright and Proto) are very cold, and even with mechanic's gloves on the uncovered steel transfers the cold into my fingers. They get so chilled the joints actually hurt.
The polymer handle on the ZEAL ratchet, I discovered, is warm to the touch and doesn't freeze my fingers. I can work much more comfortably, and for a longer period. Big win for the ZEAL!
I'm now planning my next ZEAL ratchet purchases. I guess they really do know what they're doing.
curious on opinion about Japan ratchet drivers like Koken, KTC, Vessel.......etc.
Question: Who makes the best stubby ratchet driver?
I bought the Vessel stubby and I like it and will keep it but the handle is very short.
I like the size, feel and shape of the Bahco but curious on opinion about Japan ratchet drivers like Koken, KTC, Vessel.......etc. There's side play in my Vessel ratchet, it's fairly loose in side play and adjusting the direction is not the easiest while using it. The back drag is good.
Thanks
I like the Vessel stubby I got, but also have some side play.
Interested to hear of other options.
img photo hostingEveryone always talks about just how light and pleasant the zeal floating pawl backdrag is; well one of their recent December videos showed actual values:
just fyi, that figure is in their catalog. the first several pages of the zeal section are worth a read if you haven't seen it. that and the vid you link to serve as a good intro to zseries.
also, that video was published in english as early as 2018 on their actual channel:you're looking at a repost of the video.
edit: oh snap, i see what you're saying! the vid you linked to is a rework featuring their new mechanism!!!
the vids are so similar that i didn't notice.
I know this is OT, but all these Nepros and Koken ratchet posts make me want to buy one. Even though every since I got my Milwaukee 3/8 M12 ratchet.....I barely pick up my SO Dual 80's.
Think I might just try zeal extensions and sockets!
Z-series should also expand on their extensions to have a variety of lengths. Their lineup has remained the same for 10 years.
Come to think of it, I rarely use wobble-fix extensions. Instead, I use my Z-series universals all the time.
KTC is selling a new Taiwan-made 18V cordless, brushless, torque-limiting impact wrench. Looks like a Milwaukee, tbh. JTAE473
I don't really see why one would choose KTC over Makita, tbh.
https://ktc.jp/files/catalog/photos_l/jtae473.png
https://ktc.jp/files/catalog/photos_l/jtae473_led.png
I use Koken wobble extension and I lost a couple of sockets inside the engine compartment. While pulling out the extension, it accidentally hit the chassis and the socket dropped off. It's getting too expensive for me to lose Koken sockets this way.
Nice photos. I have the fixed extensions. Need to get those nice universals. Should I get the non Zeal universals to match the non Zeal extensions? Any compatibility problems with regular extensions/sockets and Zeal universals?
I have both the regular and Zeal universals, and near as I can tell the only difference (other than the profiling on the bottom) are the retention cuts inside the female portion. They're similar to the enlarged retention grooves pictured in the catalog. There is a small possibility that the retention ball is of a slightly different diameter, but I don't have an optical comparator to measure them.
Trying both universals on American (Proto and Wright), Ko-ken, and Zeal ratchets, they seem to fit similarly. The fit of the Zeal universal on the Zeal ratchet might be a little tighter, but it's very close between them. However, when attached to an American ratchet, particularly the Proto, the Zeal universal is much harder to remove than the regular version.
As to socket retention, there seems to be little to no difference with American and Ko-ken regular sockets. I have no Zeal sockets to test.
It's likely that the true benefit of the Zeal universal only comes when it's put between Zeal sockets and ratchets. This would make sense, as Ko-ken seems to have designed them as a system. Other than the difficulty removing the Zeal universal from my Proto ratchet, there seems to be no downside to using either with non-Zeal products.
Here's what I have close at hand. Two stubby Vessels, an Anex and a Sunflag. Also a full sized Vessel that can be used as a stubby if you remove the blade. I haven't noticed much of a difference in bit engagement, but the Sunflag has the lowest backdrag. It also only has 10 teeth.
I seldom use stubby ratchets, but do employ full sized ones often, and like tanukiboy, I've found that I often unintentionally twist the direction control ring of the Vessel. I suppose if I held it "correctly" that wouldn't happen, but it does. So my go-to full sized Japanese ratchet driver is the Anex 397-D that he provided a link to above.
img photo hosting
Ko-Ken released another video of their new 72 tooth ratchet on You Tube today. Unfortunately, if you read the text that accompanies the video, Ko-Ken is only releasing the 3/8 72 tooth zeal ratchet in 2021. No word on 1/4 or 1/2 drive versions.![]()
Which driver are you referring to?Question: Does the lower part of the grip where the label is rotates with the shaft or does it stay stationary like the ball grip part?
