MattGavriloff
PIERCE is correct, I am "mid repair" on a very similar situation. Problem is I'm also "mid too many other things" to devote the time I'd like to that project, or this post...lol
The quick and dirty is I have currently filed/ground/sanded the retaining block to fit, you can see the initial fit, and then where they will be once it's done. The retainer is not "tight" to the nut, there's a bit of wiggle (1/16" or so). Reason being my screw isn't perfectly straight so we've decide it's probably unwise to have the nut completely rigid.
Next steps are, finish my thread repair because I still haven't gotten to that, finish fitting the screw to the nut (The bend in the screw is requiring some...massaging), and then fit the outside of the nut, and the inside of the slide together. I asked PIERCE to add the additional tube on the outside, for as much additional strength as possible, knowing I'd have to take some areas of it down potentially half again as thick. I'd rather have to remove now, then wish we had added more thickness later if it broke. I'm happy with how strong it looks, and the thread alignment inside is amazing!
I really want this big girl back in action, even if only for my own amusement, but it's still going to take some time...I knew this, I'm just impatient...lol
And again, I want to thank PIERCE for donating his time and skill to my frivolous project. I certainly do not need a 6 1/4" vise, but his willingness to help shows he understands the pleasure of resurrecting a big old tool.
That's all I got for now, I've gotta get some sleep tonight or I'll never make it through tomorrow...lol
I measured some of the grooves. Unstretched they are about .159-.161. The stretched ones are .165 to .170 at the worst. (tough to be precise since there is some wear, and gouging in places)
