If you saw my
glider post above, you will remember I ended it with a "stay tuned" teaser and promised to share with you my second project, another patio glider!
Found it on a local social media sale page for $10, about 9 miles SW of me.
Being a glutton for punishment, I decided this project was good enough to fit on the front porch and light enough to move to the backyard patio if we ever needed extra seating. You see, it is almost all aluminum tubing or an extrusion.
The seat section has metal roller bearing wheels and the lower "track" is a rail the wheels ride on. The spring loaded fork keeps it all together and returns the glider to its neutral position....
The wheels are concave and ride on a round fiberglass type tube held in place by the base of extruded aluminum. The bearings stay clean with a fiber washer. Repacked the bearings and replaced the wheels....
That fiberglass rod the wheels ride on looked pretty worn and you could hear the wheels digging into the aluminium base. I needed a new fiberglass rod or "rail" for the wheel to ride on. Looks like these fiberglass driveway markers I use during the winter time might just fit the bill! The wont slide into the extruded channel but no big thing....
The wheels would ride good on the taller round cylinder and I could just cut to size and screw the ends into the base!
I made sure the "springed fork" had enough clearance to afford a taller rail...
The whole assembly rides taller off the base and nothing grinds...just a smooth glide!
Since I bought cushions for the last glider, I did make sure I could find cushions for this glider too.
These red cushions match the swivel chair cushions already on the front porch....even have a matching cover for the winter time.
Another small project finished to serve our needs for the rest of the time we spend "gliding" on the front porch, watching the traffic go by.
