Depends on the led bulbs, are they the ones with hot/line and neutral on the same end? and are your current lights rapid start t8? If so the current tombstones are shunted(both pins tied together) and won't work with the bulbs that have line and neutral on the same endI bought and installed these lights a couple years ago, they were in the office at the Hill. When we started the remodel I pulled the bulbs out, as I remember there was something about shunted or not shunted tombstones and I feel like I had to swap them out, I forgot to keep them and the old fixtures are long gone. I will have to do a bit of research again, once I pull one apart I should know if they work or not.
That's a really lousy place to hide a body.Went digging in the deep storage, found some wire I needed, then a couple other things, I grabbed a bin to see if it will work for what I want to setup, also grabbed a big hydraulic C press, my neighbor is trying to get some pins out of an excavator track and it may help. Now to commence shop Tetris.......
Ah yes, Graceland.
Don't count on prices going down. With inflation sitting somewhere around 15% (Thanks King Biden) i don't think we see a return to the old pricing.Hopefully it will go back down, by the time it does, I should have a handle on what I need. I will be saving and reusing the lumber that I remove for sure, not going to be wasteful when wood is more expensive than ever. I hate to say it, but I may resort to sawing some lumber, assuming I can get Dad's sawmill to cut straight boards instead of the fancy tapered ones it does now.
I haven't even left the house yet, but I need to drop off some things at the SG, then go back to the Hill and assess some things. I know I need to order some supplies, but I want to make sure that I get what I need. The little garage attached to the house needs to have the lights rewired, I took the fluorescent bulbs out and have LED bulbs to put in, but I think I need new tombstones to make it work. I have to yank one apart to see.
I suspect walking through your various storage sheds would be amazing for most of us. “This is cool”….”what’s that…oh that’s cool too…”
Oh, your talking about the C clamp! I thought I missed a picture of some female!
That is what I think we will need, although 10 tons is better than no tons. Heat will be our friend.When I had my John Deere 420 crawler tracks
Pinned and Bushed, the local Deere Shop used their track press which is a 100T rig. Here’s to
hoping you both don’t need that type of power!
Believe me, It is.I suspect walking through your various storage sheds would be amazing for most of us. “This is cool”….”what’s that…oh that’s cool too…”
