Radial master cylinders are a pain in the **** to bleed on a good day. Have you tried reverse bleeding? Big syringe full of fluid on the caliper bleeder, crack the bleeder at the master and push fluid through backwards?
Now that you've got some pressure you may be able to pump the pistons out a bit, crack the bleeder at the top and push the pistons back in.
Is the Tesa tape the cloth type? There's actually many, many Tesa tape varieties, including plain old electrical tapes.
Our local KTM mechanic suggested something similar for the ABS - push the pistons back in to force fluid back up into the system and then bleed it again. I'll give that a try tomorrow.
You got this! Just don't try to weld titanium to stainless and you'll be fine.
sent "yesterday" from my DeLorean
Thank you so much Sean - really. I don't think I "nailed" it but I'm happy enough.
Sorry for the cross posts from ADV - I only have so much time so I try to write these so they make sense for both...
So the seat latch was a detail I got bogged down on but then there are details that I want to focus on even if I miss other things. You know, like brakes. For me that was the exhaust hanger. A small part of practically zero importance to anyone but me. For me it represents the first titanium part that I'm welding for a bike. In the hierarchy of welding I did steel, stainless, aluminum and now I'm learning titanium.
I bought a collection of titanium tube off ebay that I wanted to play with and after making up a test part, cleaning it meticulously and tacking it I could hear it cracking. Not enough heat? I did a few more and they kept cracking. I finally added filler and got the tack to hold - this was going to be way harder than I thought. I finally got a full weld around the part and it looked pretty good and then... I broke it with my hands.
How the **** do people make bicycles from this stuff? What the hell? I texted my Sean (who you know builds
amazing titanium bicycles) and whose lessons on ti got me started. He walked through my settings, my purge, my filler and nothing made sense.
So he just drove right over and as soon as he picked up the tube he said, "This is too heavy - I don't think it's titanium" which is what I thought at first and so I spark tested it and it sparked white. So Sean tried welding it and it cracked on him too. He tried a few things and finally said, "I don't know what this is but it's not titanium."
What I didn't realize is that when I spark tested it I ground the end of the tube I had broken off and it was the titanium filler that was sparking. The other end, I eventually tried, sparked warm and yellow like you'd expect from stainless. So in fact I paid a small fortune for some cheap stainless tube.
Oooooooohhhhhh. I'm not as stupid as I thought. I mean I'm stupid to have bought titanium off ebay I guess but at least my technique wasn't
too bad.
So I'm no expert on titanium but just like stainless it must be back purged. It used to be thought that you needed to weld it in a bubble but that's not the case - it just needs argon front and back so I spent a few hours making up fittings for all the tube ends and drilling and prepping the tubes. And in the middle of that my lathe crossfeed just locks up. I can't get it to turn without huge effort and so I stop and take it apart...
Evidently you need to take apart and clean your lathe more than once every 10 years...
I don't know why it chose today - maybe some bronze chips got in there and were the thing that put it over the edge but I spent four hours taking the whole carriage apart and cleaning it and putting it back together.
But back to the exhaust bracket!
The bracket is a series of compound angles and cuts and titanium requires a zero gap fit up so you have to nail the fit. This, because it requires more precision than I'm used to, took me a long time.
I'm smiling because the lathe is fixed and I haven't realized I'm almost out of argon. It was the sweet spot of the afternoon.
Welding titanium is very different from anything else. It needs zero gap fits and then you tack weld the entire joint. These are the "tacks" which look like finished welds. My color isn't too bad but I did keyhole twice. You need a lot of heat quickly and briefly. Too much heat and it just melts and you get a hole. Not enough and it retreats. I think of welding different materials as having an envelope of viability. Steel - you can pretty much weld that within a 20-50amp range and be okay, stainless is like 15-20, aluminum let's you get away with 10-15 and ti needs you to be within 3-4 amps it feels like. It's a narrow zone.
The other thing that makes it much harder than aluminum is that needs huge argon coverage front and back. You have to weld with a big gas lens and a back purge so you're using double the argon as other types of welding. That I discovered when I ran my argon tank out 20 minutes after the welding supply closed. Usually you do that on Friday at 5:05 so I've learned my lesson and I had a spare tank of Argon waiting in the wings. Yay!
So there you go - about a day and a half of effort into a simple bracket. I did save 200 grams though so that's about 13 grams an hour.
This is what the system came with - stamped steel. My bracket weighs 73 grams - a savings of .0001% off the total weight. I just
know I'll feel that weight every time I twist the throttle.
If you know titanium you'll see that I've gone too hot on my second pass. My tacks are fast and they have no color which is what you want but my second pass - the coverage pass - uses filler and I'm not as fast/good when it comes to adding filler and pulsing so I put too much heat in. They should be colorless and shiny silver. It feels very strong and springy so I'm hoping it will hold up despite my less than perfect execution.
But!
I made my first titanium part! It was small, difficult and complicated but looks, to me at least, really amazing and is exactly what I imagined. I learned a huge amount as well which is always something I'm trying to do and I had the time as I'm waiting on the remaining parts.
An interesting side note: I polled people on Instagram about what angle I should mount the pipe and while the majority said higher there was a very vocal group that took the time to write me and ask that I match the angle of the subframe tube so that the pipe and subframe were parallel. I hate to disappoint those folks but I feel the pipe has to be higher so that it makes a closing angle or triangle between the pipe and subframe. Angles create tension, command attention and look aggressive so I had to go with the pipe mounted about as high as it could go.
Next up will be a titanium luggage rack which should look good against the new tail.
And finally I got to clean my lathe - I mean that was on my list sometime in the next year or so...
Tomorrow I give the front brakes another go, start to fabricate the tablet mount, install the hydraulic clutch and give it all a once over for tightness. I should be getting the
new triple clamps from
Rottweiler (and a few fun bits too) and they shouldn't be too difficult to get on the bike. My fingers are crossed for bodywork which is arriving from all corners of the globe.
And I'll leave you with this photo - the
Aurora-Rally Tower in all of it's complicated beauty shining through the clear screen. When I asked Dimitri to leave it all aluminum I was hoping it would look really cool behind the clear screen and it looks even better than I imagined. I can't wait to get this thing finished. While I loved the 890 for all it's function it wasn't as thrilling to look at as the 950 was but this bike excites me now every time I walk into the garage - it's different and beautiful and complicated in a good way.
Gregor
PS Anyone local who wants to head to the
1 Moto Show this weekend and see how much I finished can get a 20% discount on tickets with this code: SAKUMOTO20
