That's a good 6 in 1. I bought one of those plastic craftsman truck boxes in 89. I kept a 1/4 drive set and a test light in it.Went by a regular estate sale and picked up a Craftsman plastic tote and 4 tools. Enderes 6-in-1 with both bits, an X-acto mini block plane, a 10" Vise grips, and a solid brass hose nozzle. Nothing I "needed" but I can't pass up useable stuff. Spent eight fitty for the lot.
Yup, 1.8t eurovanI spy a 1.8T
That and the fact I was able to get it for under $30 is why I was willing to take a shot.That is a good looking ratchet.
I'll post up some pictures once I have it.Please post a review once it arrives. From the backside it looks like that latest 90T Gearwrench stuff. I'm curious if it's looks the same on the anvil side.
Is that an air powered impact?
Yes, an Astro Nano Flex. It and the reg Nano have more power than they should given their size.Is that an air powered impact?
couple more...
Yup. 4425. The AES kit is really good.4425?
That and the AESWave terminal kit have saved me a lot of time and made me a lot money.
I have been looking for the 68100 tool, where did you find one? It looks like it has been discontinued.Some more pickups...
I stumbled across it on the Napa online site. Hard to find it on their site. Weird and glitchy. You can try to call their online number. Don't email them....they will respond with "call us during business hours".I have been looking for the 68100 tool, where did you find one? It looks like it has been discontinued.
I was looking at that impact. Kinda torn between the regular nano and that one. They also make a long handled version as well.
Since this is GJ I have to give the obligatory 'Get them all, duh!"I was looking at that impact. Kinda torn between the regular nano and that one. They also make a long handled version as well.
Yeah...I know what you mean. I have almost the whole Milwaukee automotive line of impacts and ratchets, grinders etc. I still like my air tools especially my die grinders and cutoff wheel (I have them in Milwaukee M12 cordless too....and they're meh). Also I really like my Mac (SP Air) 1/4 drive ratchet coo MIJ(bought new in the mid 90's) and my Rodac air hammer. I have the Mac composite 3/8 impact (Probably an IR) and probably don't need the nano (I have the M18 Mid torque 3/8, Mid torque 1/2, also the M12 stubby fuel 3/8.Since this is GJ I have to give the obligatory 'Get them all, duh!"
TBH I don't use my air tools all that often these days only because I have compact battery impacts that will usually do in the same places BUT it's nice when I have to be able to get an air impact in places I never could before, to zip off brake calipers and brackets and whatnot. When my battery versions wouldn't fit the Nanos have helped me more than once get at crank bolts & such that I otherwise if I followed the service manual's advice would have had to pull the radiator to get at. It's nice to be able to slip a piece of cardboard down in there to protect the rad and save at least 30+ minutes on a job without too much inconvenience otherwise. I hate dumping coolant and refilling if I don't have to.
I love that lift! Who makes it?Got me another hydraulic lift cart, well "stand" actually. I have a HF lift cart but it's too bulky to use in my limited workspace. This one is a dirt bike/motorcycle work lift stand.
Gonna use it for things like getting my super spacer on the mill table. That little sucker weighs just under 80 lbs. Will probably use it for my drill press too that weighs 85 lbs. I can still lift them but I've got a bad back & as the years go by I know it will get tougher for me to lift them. I can already feel it these past couple of years. Tested it out today, I love this thing already.
Bessey magnetic wand. This one is just a cheapie, the USA made ones cost way more than I wanted to spend. Probably won't get used that often, I've lived without one for years. But it does work fine.
The one I got is branded Durhand. I got it from Aosom. Currently $220 (used to be $180 pre pandemic/inflation) but I found a 15% off coupon & got it for $187. It came quick, they shipped from a warehouse close to me so I got it the very next day which I totally did not expect.I love that lift! Who makes it?
Do you know what "sloppy seconds" are ?
Where did you pick up that oil pan? If you don't mind.I received the Williams deep 3/8 SAE set that was back ordered. Also picked up a 1/4 Hazet ratchet and a new oil drain pan from Hazet.
curious to see why you picked up some singles over the gearwrench set of 8-25mm or w/e it is nowThe first of my extra long ratchet box wrench’s turned up this week, I forgot to take a photo of it when it came in, so here’s it when I started using it. I’m really pleased with it, works great.
I wanted the full set of these, but they were coming in at over $1000…you know it’s bad when the snap on guy says ‘these come with a lot of lube’. So I ordered the 10, 13, 16, 17mm for now, will pick up the 18 and 19 when my bank balance recovers
