Had been facing a high pitched exhaust rattle noise on the Patrol for a few weeks now and it was only happening at a particular rev range, hence intermittent. Got down under the car today to find and fix the issue and isolated the noise to one of the exhaust hanger brackets. Now the issue is that this bracket is in a really hard to reach spot - between the transmission itself and the transmission tunnel (body shell). There’s Barely any room for me to slide my hand in to reach the bracket, and it’s got 3 M8 screws that are reasonably tight from heat and rust (like all self respecting exhaust fasteners should be haha). Leverage is an issue and you can forget any kind of power tool here due to space constraints - see pic below - on the left you see the transmission pan and on the right is the exhaust down pipe with probably 5-7cms of space between the two.
And that’s where the bracket is hidden… now I found that the bracket is missing the two rubber mounting grommets/bushes which had probably been damaged due to heat and age. I have rubber bushings that match but to install them I need to take the bracket out.
First I sprayed some Wd40 and let it sit for 30mins, then tried a Wera 12mm ratcheting spanner, too short to give me enough leverage to break the rusted fastener and remember there is not enough space for me to put some weight behind the spanner
Next I tried the KTC 3/8 breaker bar (400mm IIRC) with a Ko-ken Zeal 12mm socket (because regular sockets are too tall to fit there - failed again because the breaker bar is too long to allow for any angular movement
Finally I used the Ko-ken Zeal 3/8” ratchet with the Zeal 12mm socket and voila, it gave me the right amount of leverage to break loose the fastener and the fine tooth gear was worth it’s money due to the extremely low swing arc.
So I took out the bracket and installed the missing rubber grommets
Best part was when it was time to install the bracket back in the car, There was no way I could hand tighten the screws due to space constraints so, the excellent (Zero) back drag on the Ko-ken Zeal ratchet allowed me to thread in the 3 screws from start and then torque them up correctly, no way it would have been possible if the ratchet had any amount of back drag in it.
I think I just recovered all of my investment in the Zeal kit
