Pliers That I Find Useful and Some I Don't. Tell Me Your Preferences
Garcky
Twin Cities Metro Area, Minnesota
My Dad, who was a master mechanic and very handy with all things that involved using tools, absolutely detested ordinary slip-joint pliers. If you wanted to rile him up, all you had to do is grab a pair of ordinary slip-joint pliers and look like you were thinking of using them for something.
"Put down those damned pliers!" he'd roar. And he meant it, too. And with good reason. Using them to do anything with a fastener would quickly turn that fastener into something worthless that no tool could ever grasp again in any useful way.
He wasn't opposed to all pliers - just the garden variety of slip-joint pliers. It didn't matter who made them. He hated the solid-gold ones from Snap-On as much as he did a pair from the dollar store. Because of this, I have always cringed from just looking at a pair of them. Is that wrong of me?
Anyhow, as I've gotten older - very much older - I've grown to recognize that there are some very useful pliers. Some of my favorites are:
Channellock Pliers - Sometimes called "water pump pliers," or a variety of other names, these actually have many uses. Adjustable so their parallel jaws can fit almost any size of object, while allowing a strong grip with their long handles, they are very useful for holding and grasping round things when you don't need something like a pipe wrench . Their disadvantage is their tendency to pinch your fingers if they slip while you're putting pressure on something. You can have several pairs of these in sizes from 4" to 24". You should, too.
Vise-Grip Pliers - Available in a bewildering range of jaw shapes and sizes, they are something like the channellock pliers described above, but they can clamp down on an object without continued hand pressure. As a wrench of last resort, they are the tool you reach for when nothing else will do. They can also be used for jobs like permanenty replacing the handle on a LaZBoy reclining chair. In fact, everyone should have a spare pair for that use - just in case. You cannot have too many pairs of these, so buy them frequently and put them everywhere.
Side-Cutting Pliers - Also known as diagonal cutting pliers or "Dikes," these are the go-to tool for two jobs. Cutting wires and gripping cotter pins for removal, using the pliers as a lever. Always buy a good brand of these, because the cheap ones will be ruined when you try to cut a wire coat hanger, which you will do at some point, ruining them forever. Don't cut heavy piano wire or spring steel wire with them, either. Trust me on this.
Lineman's Pliers - These combination pliers include both side cutters and toothed jaws. If you buy a good pair, they will cut coat-hanger wire quite easily, due to the increased leverage of cutters close to the pivot point. For substituting as a wrench, though, they're not much better than the detested slip-joint pliers. Get a pair at least 8" long, to make cutting coat-hanger wire easier. And trust me, you will need to cut coat-hanger wire often.
Needle-Nose Pliers - Also called long-nose pliers, you will need several pairs of these in different lengths and thinness of their tips. Long ones, capable of almost reaching that nut that fell down behind the bell housing, are also available. But, so are extendable magnets. I'd get the magnet thingie. Some needle-nosed pliers also have side cutters near the pivot. Don't use those cutters. You'll ruin the pliers. Seriously. Nobody knows why the put them there.
The pliers listed above are tools worth owning, in my opinion. There are other types of pliers, but most are just variations on the five on this list. However, if you commonly work on drum brakes on vintage cars, you will definitely need a pair of brake spring pliers. If you don't work on such cars, those will be of no use to you whatsoever.
Now, you might have other favorite plier types. We'd all like to know about those, too, as long as they are not slip-joint pliers, so...
slowtwitch73
Hellgate
Yup.. I have al those and only use the ones you have in bold.. unless i'm just grabbing a hot part or something in which case I'll use the slip joints. I cut the handles off one pair for some cramped work under a dash.
RoninB4
Under My House
I usually hold tools from Horrible Freight in disdain but I bought a set of these after using one from a co-worker. They're great for pulling/installing water line hoses in tight places on injection molds. As for other pliers, when I use them per the design intent they all work just fine. Vise grip types are a last resort, never a first choice.
dnschmidt
Phoenix, AZ
There are updates to your list.
Channellock = Knipex Cobras
Vise-Grips = Brennen or Milwaukee (or in my case TOPTUL since I've got a lot of them and I bought them cheap and their quality is excellent.)
Linesman's Pliers = Klein, Knipex or NWS
Side Cutting Pliers = NWS FantasticoPlus
Needle Nose Pliers = The new Snap-On ones that everybody including me raves about.
Komet
WA
I really like needle nose pliers with the 45 degree bend at the tip for automotive work. So many times I've needed to grab something at an angle, and the bend is perfect to get around obstructions.
Shop-hound
Calgary, AB
I too, hated slip joint pliers until I discovered the 47ACF pliers. Will make anyone a believer.
Those and Knipex twin grip
It's unfortunate that most peoples' first experiences with conventional slip-joint pliers were with shoddily-made cheapie imports.
Now, if they'd started out with a fine, high-quality, well-designed and manufactured device like one of Wilde's "Flush Fastener" models, they'd have a completely different opinion of slip-joint pliers:
Actually, you don't even need to get that fancy.
You can get away with mid-priced stuff if it's of decent quality:
Neither this nice old pair of Challenger 318 8-inch slip-joints OR these nice Proto 278 8-inch slip joints (now in the possession of GJ member @Smokeshow69) ever pinched my fingers even once. Not once.
(My father stopped carrying "Challenger" in the mid-1960s, to give you an idea of how long I've been using those.)
(I honestly don't know where those Protos came from, but I put a hell of a lot of miles on those too with no pinchie-squeezie stuff.)
Use good tools = no problems.
Gotta expand your horizons - steer clear of that Globemaster stuff.
Renegade1LI
long island ny
Sometimes i wonder why I waste time and money buying so many different tools for my guys. They have every correct tool and I still see them grab for chanelocks and the adjustable. I even bought them all new knipex, nope still in packaging.
G
Garcky
Everyone has favorite brands, eh?
G
Garcky
I have the Proto ones. My late Dad would still yell at me if he saw them in my hand. :ROFLMAO:
Dakotadadv8
I have the CM Professional set as well as the Snap on set. I use them more on home repairs and they have been useful. The Snap on Talon grip are very good.
2ndGearRubber
Pittsburgh
^ Those are key.
On my cart - I keep a 10" set of cobras. 8" dykes which are currently snap on. 8" needle nose which are snap on. 12" 45* need nose, currently tsundoa. 8" linesmen, currently knipex. 8" long reach cutter plies, channellock 748. 12" straight needle nose, currently sunex. Steck body/trim pliers 21720.
I have some locking pliers too, 11R vise grips, 2 pair, and 1 pair of snap on eagle grips, and one pair of malco narrow jaw eagle grips. Those are the everyday use pliers. I probably have 75+ pair still in the box.
JWC86
These two pliers are probably my most used pliers by far.
Yo add to the OPs general list of plier styles I would add duck bill pliers. I find them useful as a general purpose and not bad for spring hose clamps.
F-22
No toolbox of a working man is complete without fencing pliers. When the job gets tough, you grab that combination hammer/pliers/prybar/nipper and show who is boss!
I did not know those exist, and I have lots of wire fences - a big electric fence to keep the sheep in... It always requires some maintenance and these seem ideal! But my fence is made of zinc plated steel wire between 10 and 7 gauge (2-3.5mm). Would those shear-cutters be enough? I normally use this style:
But I also need to carry a hammer with them... The fence pliers would make sense to have (and I'm itching to order some US pliers from Amazon anyway, maybe chanellock).
Anyone knows of a version with this stronger style of pinch cutters? I think they work much better for thick wire.
Recently found an unexpected use for my Tsunoda chain link pliers - they are avesome for E-clip circlips! I bought them thinking it'll be used really rarely, but they come extremely handy for assembling motorcycle engines (can easily fit or remove those clips deep inside an engine where it's usually hard to access). They have rounded jaws so it always sits in the centre, it's like they're made for it (well, they chain clip is kind of the same thing anyway).
Ricky Joe
Roanoke, Va.
I have several pairs of fencing pliers and don’t have a fence and have never that I remember used them for fencing. But I have often found them handy when something requires a Neanderthal approach.
lardy1
Todays designs and options have relegated my slip joint and Channellock pliers to drawer duty. They rarely get called to duty anymore.
M6erfan
'Merica!
I have a pair of linesman pliers. Hardly ever use them in automotive/motorcycle/shop use. Maybe if I was an electrician . . .
I have a pair of these kind of oddball needle nose soft jaw pliers that I use often, I have them specifically for removing soft brass motorcycle carburetor emulsion tubes without distorting them
Outwest
Northwest
I don’t generally use fencing pliers for anything other than fence, unless that’s all I happen to have on hand. Channel locks are pretty good, but Moore Makers are the best I’ve found. Old Cresents are my favorite, they have the same style now, but off shore production and the cutting shear will chip easily. That said, my knipex mini bolt cutters accompany my fence pliers when I’m building fence. The Knipex are just better for cutting.
bwringer
Indianapolis
Duck bills have their place too
Yep, I use mine far more than I really ever thought I would.
My favorites are the Doyle "flat nose assembly" pliers from HF. I can't fathom why they don't call them "duckbill" pliers like everyone else on the planet, but they seem to be just the right width, etc. for a lot more things than others.
I'm also very much a fan of simple dipped handles like this. I detest the bulky greebled "dis-comfort" handles so often glomped onto otherwise good tools. But that's somewhat down to personal taste, I guess.
I have a pair of Tsunoda duckbills that are a little smaller, but less than half as useful.
On a related note, one of my pet peeves in many situations are pliers that try to be multipurpose with wire cutters, crimpers, weird grippers, etc. but only end up being weaker and less useful. One of the reasons I bought the new Icon needle nose Snap-On clones is that they are pliers... and that's it. Sure, if you're doing wiring then cutters, etc. can be useful so you don't need to carry as many tools, but for mechanical work, you primarily want strength and precision.
Dave455
Sussex, England
My most used style of pliers are, and always have been, the traditional British / European pattern “Combination” pliers.
Unfortunately, it’s a pattern that’s very uncommon in the U.S. Very different from slip joint pliers (which have their uses, but I find frustrating to use in place of combination pliers) and different from Linemans pliers, which I consider something of a specialist tool.
I think that the only U.S.manufacturer to offer these is Channellock, and even then they’re rare.
But, the lack of availability of combination pliers, explains why U.S. made long nose pliers tend to be stronger!
CoogarXR
Most of my work is electronic anymore, so I use a lot of the smaller precision pliers/cutters. I LOVE my little 4" Xcelite flush-cutters. I have a pair in every toolbox/roll. I probably use them more than any tool in my pliers/cutters drawer. They make nice, flat cuts in zip ties, component legs, anything I need. I use various needle-nose, especially the curved ones. I also use transverse end cutters (both 90 and 45 degree) for making cuts in tight areas.
lardy1
I bought these awhile back but I really don't use this type of plier much. I had two sizes of Channellock since Christ was a kid and wanted something nicer. I really like NWS pliers. I have a few pair and am expecting a set of pressing pliers in my mailbox today for crimping end sleeves.nws.jpg
seber
Deep East Tx.
As I get older, the standard slip joints get used more and more. They are just about perfect for opening bottles with stuck caps. Another one I use often are parrot beak. I use them where most of the people here seem to think pliers wrench is the answer.
G
Garcky
I have a pair of Craftsman RoboGrip pliers for those tight bottle caps. My wife uses them, too. Simple. They're in the cooking utensil drawere next to the refrigerator.
