Tried to get to installing the new wheel bearing / hub on my FIL's Silverado last night...got sidetracked with my 04 GT. Hearing a not so normal 'clunk' / 'clank' type noise from it. Only noticed it when I was in an enclosed parking garage - moving steering wheel side to side with tires on the ground will reproduce it. Car drives fine. I've already done ball joints, outer tie rods, calipers, rotors and pads. So I get it on jack stands in the shop. Can't reproduce the noise when the tires off the ground. Lovely. I'm betting it's the infamous rack and pinion noise these tend to make. Got a set of the revised Ford R&P metal sleeves on the way and I'll order some Poly rack bushings to install while I'm there.
Also - at least one of the front control arm bushings is shot. Which *****. I just did ball joints. I am not installing poly bushings in the control arms - no thanks - and replacing the pressed in steel sleeved CA bushing in these thing arms looks fun...NOT. Odds are I'll just buy new control arms. Problem is the Moog arms use a non greaseable ball joint. MevoTech makes a 'Supreme' control arm that looks pretty solid. Rock Auto has 'em for less than a $100 a side. Hell it's almost $50 for just the stock control arm bushings with shipping. Likely do the front wheel bearings/ hubs while I'm in there. I'd rather not have to go back into the front end for a long time.
Told myself the next time I unbolted the front struts (likely OEM) I was going to replace them. Probably go with Fox Body spec KYB struts. Identical to SN95 except a bit shorter - suspension gurus actually recommend these for lowered SN95 cars (my '04 GT had Eibach springs on it when I got it). Likely add poly spring isolators, new endlinks as well.
Anyway - I noticed something all over the LH driver's wheel well. Got my wife to press the brakes while I was under the car. Definite leak from where the caliper meets the brake line. Installed new copper crush washers on both sides, bled the fronts, and brakes were fine today. Will check for leaks tonight - but the Silverado hub is getting done tonight. Need to tell my FIL I need to do the LH CV axle too. Boot is busted.
