vibblueser
- Joined
- Mar 16, 2012
- Messages
- 405
I recently upgraded one of my pedestal sump pumps to a submersible unit and in the process made a couple of modifications.
1. Replaced corrugated cheap plastic piping with solid pvc
2. Installed check valve which was not installed previously
3. I removed old muck/crush paver from bottom of pit
4. I added pea gravel and have pump sitting on bricks placed on top of pea gravel
I am going to be replacing another sump on other side of house and plan to do similar modifications. I do have a couple questions before I tackle this project.
1. Is pea gravel ok as the base for the pit? I have read conflicting information online regarding this. If not any suggestions?
2. This other pump will have a much longer run of piping and needs to make several turns. I plan to use long sweep 90 turns vs the medium sweep shown in the first install. Any benefits or reason to stick with my plan of the long sweep vs making due with the medium sweeps?
3. Any other suggestions would be greatly appreciated.
