kokenusa.com
kokenusa.com
I have many Koken and Zeal sockets. It should be noted that the Zeal sockets are not great for automotive or repair use. The tolerances are too tight; Paint, corrosion, damage (including rounding) to the nut or bolt head, can all cause the Zeal sockets not to fit.
I always recommend the normal Koken range of sockets unless the person knows they need the Zeal version.
For ratchets and extensions it is personal choice. The Zeal versions are definitely nice. How ever I usually grab a regular Koken piece.
What’s the intended use then?I have many Koken and Zeal sockets. It should be noted that the Zeal sockets are not great for automotive or repair use. The tolerances are too tight; Paint, corrosion, damage (including rounding) to the nut or bolt head, can all cause the Zeal sockets not to fit.
How does the smoothness and range of the hex ball compare to the regular universal?
