Even with no building inspection, you are still required to follow the building codes.
You have options other than drywall. OSB, Plywood, Metal (steel or Aluminum), and Trusscore. I’m sure there are others, but those are whats commonly used around me.
You seem to lean towards drywall, so here are my thoughts..
For 24” OC drywall, 1/2 will sag over time so you need 5/8 to help reduce it. Notice I didn’t say its a guarantee For not sagging. BTW, 5/8 is at least 25% heavier, so a few more fasteners per sheet can’t hurt.
PCustoms has the right idea. Strap your ceiling 16” OC and use regular 1/2 drywall. Problem solved.
No matter what you install, use screws and not nails!
You can use a vapor retarding paint and omit the plastic. Less likely to trap moisture in your drywall that way.
