thunderskunk
- Joined
- Oct 4, 2022
- Messages
- 130
Howdy,
I’ve made a few benches in my time.
Here’s #1 made from scraps snagged while working as a tractor mechanic:
Here’s #2 that I built in a dingy basement and it’s never coming out again, also overbuilt:
Here’s 3 and 4 that I over-built for use in the machine shop. I have 100% confidence I could toss them over a gap as temporary bridges for vehicle traffic, but they don’t make ideal benches to be honest. Bulky, hard to move, and while they have serious strength, they tend to vibrate in ways you could only tell running precision tools atop them.
Here’s one I put in the other day that’s essentially a shelf with some legs:
And this one is a shelf. If I could do it all again… they’d all be shelves.
They’ll get stain and poly one of these days.
But now I’ve got the tractor out back that needs serious benches. Nothing on it is lightweight nor clean. Not to say a wooden bench won’t work, but I don’t mind building some metal benches to beef things up and reduce the footprint. I’ve seen some awful angle iron boxes welded up.
So here’s the root question: what’s a good angle-iron bench look like? Size wise, I’ve found my sweet spot is 33” high, 2-2.5 ft deep, and - bench that overhangs is a ton easier to clean underneath and access storage, even if there’s a lower shelf. Also the benefit that if it’s not a monster truss bridge disguised as a bench, it’s easier to move when large things are on their way in and out. I’m not a weld shop, but welding happens. I’m going to have to do a lot of painting, which I’ve never done before at scale. If not metal, any particular stain and coating that’s a bit more tolerant of the occasional weld?
