Codyboy
I have some left over red iron material from the shop build.
The guys that welded up the steel were using a big truck mounted arc welder.
They did not grind off the red oxide or whatever that is on the steel. Just cut it to size and weld it up.
Can I weld this stuff with a mig welder using flux core wire and not have to clean off the red oxide?
I only have flox core wire and im not set up with gas .
