Honda, actually. The Mopar has no such warning light, nor does it have such a sensor!Mopar? Usually a leak detection pump(ESIM) failing.
Well, in fairness to Ram truck owners, the Mopar I refer to is the one in my avatar, and is from the 1960s...
We weren't worried about fuel vapors in the 60'sWell, in fairness to Ram truck owners, the Mopar I refer to is the one in my avatar, and is from the 1960s...
Tried to fix the overhead door opener. It's a Liftmaster 98022, and was working fine just the other day (isn't that always how it goes?). Now it's throwing a 1-5 error code, and we've progressed (regressed?) from a hum for 1-2 seconds (with no associated movement of the door) to just flashing lights. I've tried the manual release reset that's suggested by Liftmaster, but no luck. The safety sensors are aligned and happy. About to go remove the battery backup and unplug the thing to see if that helps, but otherwise I'm out of ideas.
It's a garage door opener, I'd like it to just work...
They look ok to me - the door's only been installed for about 1 year. I can manually open and close the door by hand just fine.Are the springs busted? it could be stalling for the weight.
I wear glasses, so I always forget. My son has gotten pretty good at getting them on his own.You are totally correct I’ll put some in his toolbox today.
If the door opens and closes easily by hand, the springs are fine.They look ok to me - the door's only been installed for about 1 year. I can manually open and close the door by hand just fine.
Other than terrible noises and metal flying into low earth orbit, how else does one tell that a torsion spring is busted?
A friend waves off safety glasses because he's so delighted with his nifty new implants. Well, he waved them off in my shop, and a flying chunk of diamond got him. Luckily, I was able to pick it out of his eye. Now he looks for the after glasses on top of my toolbox.I wear glasses, so I always forget. My son has gotten pretty good at getting them on his own.
This ^^^If the door opens and closes easily by hand, the springs are fine.
Oh, yeah, just your local friendly titanium fabrication shop. Doesn't every town have one?Not my shop, but a local titanium fabrication shop
Oh, yeah, just your local friendly titanium fabrication shop. Doesn't every town have one?![]()
At this point I've got nuttin'! No clicks, no whirs, no turning, no gnashing of gears... just a bunch of flashing lights that I'm trying to decode. I'm out of the 1-5 error code (yay?) but now the durn thing won't respond to any input.If the door opens and closes easily by hand, the springs are fine.
Does the opener work at all? Is the output of the opener turning when trying to open the door? I've had the drive wheel on the door get loose before, resulting in it just spinning on the shaft. Tighten the set screws and it's fine.
Converted--reversibly--to LED and CR 18650 batts--in two banks, so I can get damned near 24 hours burn time!Love the old battle lantern
They're not that difficult. It's just a steel strap with a vertical oval hole in it that's made to fit the oval bit on the back of your lamp. You turn the lamp 90 degrees, and push it in, then gravity locks it by swiveling down.Converted--reversibly--to LED and CR 18650 batts--in two banks, so I can get damned near 24 hours burn time!
If anyone here is scrapping a WWII warship, please save one of the bulkhead mounts for this for me!
I ken that. But there has to be some kind of spring mechanism to keep it from rattling and popping out on it's own in heavy seas--or on rough backroads.They're not that difficult. It's just a steel strap with a vertical oval hole in it that's made to fit the oval bit on the back of your lamp. You turn the lamp 90 degrees, and push it in, then gravity locks it by swiveling down.
I'll have to get some decent pics of the relevant #s off the lantern.Any relevant patents on the lantern?
Or if someone has a copy of the Mil-Spec (or equivalent)?
Are you going to do the foundation work yourself?
I have a face shield for when things are really flyingA friend waves off safety glasses because he's so delighted with his nifty new implants. Well, he waved them off in my shop, and a flying chunk of diamond got him. Luckily, I was able to pick it out of his eye. Now he looks for the after glasses on top of my toolbox.
I've taken down and replaced hundreds of them. So no, not like I imagine you're thinking. There's just a metal bracket, a little thinner than the space between the foot and the base of your lamp's bracket, with a little upset at the bottom to engage that little tang at the bottom of the lamp side of the bracket pair and tighten it. Your lamp has the tang bent in. It's supposed to point straight down to provide the springiness.I ken that. But there has to be some kind of spring mechanism to keep it from rattling and popping out on it's own in heavy seas--or on rough backroads.
Gravity isn't always down relative to the vehicle.
did I mention the onerous Italian bureaucracy??
You mean this tab:I've taken down and replaced hundreds of them. So no, not like I imagine you're thinking. There's just a metal bracket, a little thinner than the space between the foot and the base of your lamp's bracket, with a little upset at the bottom to engage that little tang at the bottom of the lamp side of the bracket pair and tighten it. Your lamp has the tang bent in. It's supposed to point straight down to provide the springiness.
My words don't describe it well, it's so simple.
Watch this video, they have a good picture of the whole deal.
It's springier than you think. It doesn't take much. Watch the flick, you'll see.It's not exactly springy.
