theoldwizard1
Other than stringing together several dual filament tail light bulbs, do such items exist ?
No need to be fancy with that stuff in my opinion.A standard 9004 headlight bulb uses ~5a on high and ~3.5a on low.1 amp I'm sure there is. 5 amp? I'd like to see that. A standard headlight doesn't even pull that much at 12v.
Can someone tell me why we're doing this?
Zim
The secondary use is to LIMIT CURRENT (by placing the test light inline) to a suspect load.To test a circuit under load.
