This is a Bosch 469 115amp Alternator from a 90's Porsche.
1. Does anyone know if that is likely high temperature tape holding the wiring to the rotor shaft? (see white band). I believe I need to cut it off in order to access the rotor wiring? Search tells me Kapton tape is a good high temp option.
2. Can anyone walk me through how the old ring gets de-soldered and if it is likely potted / epoxied onto the shaft?
