Well things finally warmed up here in the past little bit so I've been able to get some projects done in the shop.
This one wasn't a shop project but a tractor project. I had a good 6-8" layer of snowpack on the driveway that got absolutely tore all to h*ll after a utility truck decided to turn around in the driveway and promptly got stuck. Had to use the tractor to scrape it down to something half way smooth.
I started working at getting the new woodworking machines operational. I have easily a half dozen woodworking projects on my short list that have been waiting for warmer temps, so I want to get these machines ready to go. I'm putting an extension on to the dust collector so I can incorporate a collection bin for bigger chips, that way I won't have to empty the dust collector as often.
I needed to plane down a board to use for the base of the drill press, so I put it somewhat together to try it out as a proof of concept with my planer. I need to come up with a sturdy way of securing the bin, and I need to add an elbow to where the intake hose comes into the cyclone lid. As it is, that stiff hose puts a lot of sideways force on the bin. But it did work! The large chips all collected in the bin, while the dust collector bags themselves just had the smaller pieces in them.
I also need to do some minor repairs on the bandsaw. When I hauled it home I laid it flat on my trailer so that the base of it was facing the rear of the trailer. Well what I didn't know was that when my grandfather assembled it he didn't get the motor mounting bolts very tight. When I got it home I realized that 3 of the 4 bolts holding the motor on had come loose and completely fallen out during transport. The last bolt, which was holding the motor on, barely had the nut still threaded on. If I had driven much further it would have come loose, and the motor would have fallen on the road. Thankfully I should have enough hardware here to get it secured properly.
And a sunrise picture from the other day.
