I have received 4 quotes for a 50 x 35 garage addition in PNW. They all are in excess of $300K. I have also received several bids for a detached garage the same size around $120K. This is just insane to me the discrepancy between the two. Nothing sticks out on any of the quotes, it's a pretty "basic build", no crazy elevation changes, 20ft gabled ceilings but no 2nd floor, no plumbing. I do not want a detached garage unless it can be attached and open to the current 20 x 25ft garage. This only works for me if the current garage is "open" to the new garage the full or close to 25ft.
Idea: Could I build a detached garage 5ish feet from the house. Then have an enclosed "breezeway" that is 25ft wide and 5ft long to connect the two? That seems like it would be significantly cheaper than trying to build the addition with all the tie ins. I would obviously need some large beams to cover the span of the 25ft openings on both.
Is this crazy? Could it work?
