Tell "them" not to do this and to read the instructions. There are many threads on this. The lift instructions tell us (for good reasons) to do otherwise.They plan to put down better pads where the 2 post will go.
Make that door 18 foot wide. You will not regret it.On the 28 foot side. And make that door 18 foot wide.
On a I beam…
... I would place the lift centered on the secondary access door right next to it.
Wasn't sure. Could have been trying to avoid the 2 post interfering with use of a hoist. Or wants to be able to use the hoist in conjunction with the lift.
like a hoist to move an engine from his assembly bench to the vehicle, and a lift to get under it to install the transmission and transfer case... .Good point. I was thinking he's only talking about one thing but not so sure now. It can be 2 post lift or 2 post hoist depending on the area someone is in. Or be the two different things.
