Kohler does extensive bathroom lighting and mirrors to coordinate.
Had no idea. Tells you the price point of the peanuts on my gallery.
Other then price, are you OK with the nameeks you listed?
Not really. The Nameeks one has its features and faults that I find after reading about it on seller reviewsHad no idea. Tells you the price point of the peanuts on my gallery.
Do you have the stomach for your wife being frustrated with a cheap one?Not sure I have the stomach for a $1000 USA made makeup mirror.....
European wiring colors (brown, blue, green with yellow stripe), (…)
Ya know Larry, at this point can you really put a price on your wife’s face….Over the weekend I found a brand by a company called Electric Mirror (EM). The are based in Washington State but their products are made in China.
They do specify a conventional back box and use “normal” black, white, and green wiring. UL listed.
Still looking at their offerings which are in $300-500 range.
I was scrolling through Home Depot's offerings too. I didn't see that one, but they have a ton of mirrors that use rechargeable batteries selling for around $50. I know you want a hardwired one, but for the big difference in cost the battery powered ones look pretty attractive. I'm guessing that with LED lighting they run a long time before you need to charge them up again, so maybe it's not that big a deal.
A better fan will take care of the steam properly. I always shave after showering and don't have an issueI think if I went hard wired, having it heated would be a key selling point for me. It would be nice to have a large-ish fog free mirror for shaving after the shower when the beard is softest!!
I have a 110(?) CFM Broan brand fan. When I bought it, it was the most CFM on the shelf that also had a light. Its due for replacement, but the fogging issue was since this place was built.A better fan will take care of the steam properly. I always shave after showering and don't have an issue
Also oddly it is separately switched. I did not check to see if it uses a conventional wall mounted electric box.
Shave in the shower.I think if I went hard wired, having it heated would be a key selling point for me. It would be nice to have a large-ish fog free mirror for shaving after the shower when the beard is softest!!
I don't want to detail Larry's thread, but ducting (material, path and length) and placement would be next questions.I have a 110(?) CFM Broan brand fan. When I bought it, it was the most CFM on the shelf that also had a light. Its due for replacement, but the fogging issue was since this place was built.
