No, it is part of the new addition in 2004.Most likely a proprietary part used by the door manufacturer. Unless you can find who made the door, there is no easy repair. Who knows, it might be original to the house when it was built, and the manufacturer is long out of business.
It looks to me as if the screw that looks like a door stop goes though the inside door handle and screws into the white part that’s broken of the outside handleWhat part are you trying to fix? You have pics of a screw missing in the trim of the door handle, a hole in the edge of the door where a screen may have been, and a broken door stop.
I included extraneous pictures for context but they inly confused the point. The interior door mechanism attachment point where the screw attaches to has broken off. SEE PICTURE.What part are you trying to fix? You have pics of a screw missing in the trim of the door handle, a hole in the edge of the door where a screen may have been, and a broken door stop.
I didn't recognize it as a screw!It looks to me as if the screw that looks like a door stop goes though the inside door handle and screws into the white part that’s broken of the outside handle
G
So can you not take the other screw out and see what the rest of the mechanism looks like?I included extraneous pictures for context but they inly confused the point. The interior door mechanism attachment point where the screw attaches to has broken off. SEE PICTURE.
OMG, i didn't take into account the way people could interpret what they see.What part are you trying to fix? You have pics of a screw missing in the trim of the door handle, a hole in the edge of the door where a screen may have been, and a broken door stop.
HOLY ****…..I NEVER NOTICED THOSE NUMBERS. I am awestruck…..and embarrassed. I also didnt notice the logo …. AW…. Gee what do i think that could possibly stand for…I see what looks like a 2379512 in the first picture ? I would take the entire lock assembly out of the door and see if there are any other identifying marks on it. Take it to a local glass company and see what they say ?
that's exactly what happened . it could be possible to drill it out & use a chicago bolt or *** bolt etc to temporarily secure itIt looks to me as if the screw .... goes though the inside door handle and screws into the white part that’s broken of the outside handle
It not me it is my wife the wannabe engineer.pot metal ( as mentioned above) is not really repairable . and superglue is a waste of time. I don;t know how well JB weld will hold up, there's a lot more stress on that screw than you realize
I wouldn't try super glue, but depending on what the inside of the trim looks like and how much of a hole there is to go through, some epoxy might work. I don't think you're going to have any luck welding it.If I had a video feed from my house you folks would be rolling on the floor.
The wife seems to think i can just superglue the broken fitting back in because it isn't doing anything.
I repeated myself too many times, the door handle-locking mechanism is held together with TWO bolts- one is broken.
i know this is a personal problem.
perhaps i could TIG weld this piece back…..doubtful.
Of course I am not going to use anything but genuine replacement hardware……sheeeeesh! ThxI wouldn't try super glue, but depending on what the inside of the trim looks like and how much of a hole there is to go through, some epoxy might work. I don't think you're going to have any luck welding it.
Certified Anderson installer as well?Of course I am not going to use anything but genuine replacement hardware……sheeeeesh! Thx
Isnt this the perfect job for a 3d printer? Remove the brass/metal threads from the old part and 3d print the new part around the old threads.
I have a Prusa mk4s. could be easy, standard threads, fusion360 is robust but i need metal for security and durability. Prusa is open sourced, prusaUSA is in DE.Isnt this the perfect job for a 3d printer? Remove the brass/metal threads from the old part and 3d print the new part around the old threads.
Thats the next "tool on the list" for me, anyway...
Cant you encompass the brass threaded insert into the print? Ive seen this done a number of times where you print a bit, pause the print and insert the threaded insert, then continue the print - encompassing the metal inside.I have a Prusa mk4s. could be easy, standard threads, fusion360 is robust but i need metal for security and durability. Prusa is open sourced, prusaUSA is in DE.
It is more fun to design the part in fusion360 and print it all at once. But 3D filament is not for this application. Too much force on the handle when opening and closing the door or lock. Thanks for responding.Cant you encompass the brass threaded insert into the print? Ive seen this done a number of times where you print a bit, pause the print and insert the threaded insert, then continue the print - encompassing the metal inside.
