Hello all - This may end up resulting in defeat, but I thought I'd ask here - any thoughts on removing a drill press column that seems to have fused to the base plate? I picked up this 1953 Craftsman 100 specifically because I wanted the taller 67" column. As it turns out, it had spent some time in a damp corner of the garage on a dirt floor - the base is quite rusted. The column won't budge. Good news is I only paid $50 for it, and the motor and tilt table are both in great shape. The rest of it is in decent shape as well.
After a bit of scraping, wire brushing, and cleaning it no longer looks anywhere near as bad as it does in the below pic, but that column seems like it may be attached to that base for life. I'm currently soaking the area with Kroil and tapped it a few times. We'll see what happens. Any other thoughts? Heat? twist? I'm thinking now that I may just clean up and paint the base with the column in place and use it like that. Only the bottom 1/2" of the pipe had any real cross section loss, and it still is quite sturdy. The base cleaned up better than I thought. Basically I have no concerns about this area failing.
Anyway - thoughts on how I should proceed are greatly appreciated!
