Venting & insulating garage roof in Colorado
av8bpilot
Denver
Howdy. I was hoping to get some advice for venting my roof (or not) before I sheetrock everything over and blow in the insulation (closed ceiling). This is a detached, 2.5 car garage in the Denver area. I'm in the process of finishing it off with R19 in the walls, drywall, and an 18K mini-split. Currently, the roof only has two box vents on the north face and no 'intake' side for a ventilation system. Heck, they couldn't even manage to cut the box vent holes large enough. The soffits are OSB/Hardiboard and open on the inside, but have no external vents.
What kind of venting do you think would be sufficient for this? I was thinking something simple like 4" vents every other rafter span or something. I do not want to rip out and replace all the soffits. Thanks.
couch67
Ontario Canada
4" would work, maybe even 3", would be easier to drill them, just drop more of those in. I think the general rule is 1/150 venting for sq footage of the garage, but maybe research that more for your area . So for every 150 sq ft, need 1 sq ft venting, between the roof and soffit vents.
tarmy
Nor Cal
I did what you are doing about 2 years ago…the vents I used work great due to the typical afternoon breeze and the direction it faces…IMG_5567.jpegIMG_5549.jpeg
75gmck25
Alexandria, VA
You might also want to get a price for sealing the "attic" area and applying foam to the underside of roof deck. We did this with our house a few years back and it has been really efficient. It works even better because our A/C unit was in the attic, and now the entire system is in conditioned space.
You have lower humidity than we have in Virginia, so that may be a factor, but I really like how ours worked out. We used Icynene open cell foam and on the roof deck they applied about 8-10" thick. Attic temps are within a few degrees of the temp in the house.
