BonzoHansen
I have one of those. A radio shack remnant
That's low key genius. I dont have any copper nails, maybe I can strip a hunk of 8G i have laying around.
FYI, its still raining. (ok, got a break part of today, but its coming back)Hot here in NJ. No rain in sight. I get the sprinklers setup. Now its pouring out. I made it rain
The old Red can of flammable CRC was the best but hard to find now, they non chlorinated, non flammable in the Green can and non flammable, chlorinated in the Red can, neither as good as the old flammable stuff.Off subject, but how do you like the CRC Brakecleaner? I just started using it at work, seems ok, but prefer the CarQuest that I cant get here any longer. I tried a can of NAPA Macs, nasty, nasty stuff. Made my hands sting through nitrile gloves.
That will workThat's low key genius. I dont have any copper nails, maybe I can strip a hunk of 8G i have laying around.
I think the "portability" of it will come in handy when it's not convenient to do the soldering work on a table / benchtop...That's low key genius. I dont have any copper nails, maybe I can strip a hunk of 8G i have laying around.
I can have two independent sound tracks in my editing program--Davinci Resolve. I can have one recorded via the awful mic on the camera--and already synced to the video--and one via the wireless. Any good sound--like a clap--and I can then line up the two using the sound level graph and then delete the one recorded on-camera.Timm, give yourself some sort of "synch count" at the start on both devices and it should be pretty easy to hit.
That's what I have.I have one of those. A radio shack remnant
The flammable stuff with the “PowerJet” nozzle is ever so much fun when used as a flamethrower. Or so I was told…The old Red can of flammable CRC was the best but hard to find now, they non chlorinated, non flammable in the Green can and non flammable, chlorinated in the Red can, neither as good as the old flammable stuff.
An actuator bracket broke on a Lazy Boy power recliner, so I did what any man card holder would do. I used a chain hoist to get the base unit up onto a work table, removed the bracket for tig welding, and then used it again as a helping hand to hold the foot rest at an exact point to get a piece of the mechanism aligned during reassembly. It got used one more time to load the base onto the Carryall for the return trip back to the house. Disassembling and reassembling one of those mechanisms alone with all the pieces and linkages is akin to a monkey trying to screw a football on a wet tree limb. I did get a good supper as a show of appreciation for my efforts though.
Wow! That one's heavy duty, mine was all plastic.Saw this Huffy Big Green Machine at a yard sale this afternoon, $10. The tire was flat and it had been left outside. I put a patch on the inner tube, lubed the bearings and adjusted the brake. Hit all the joints with PB Blaster. The seat adjustment fastener was frozen. Drilled it out, used a new fastener and two fender washers. My 9 and 5 year old grandkids will be here a lot over the summer. They have bikes here but this should be fun as well.
Never argue with success is my motto!Grabbed a test light, wire strippers and a few connectors of various sizes so I could fix the lights on one of our work trailers today. Got to the job and immediately found the problem upon pulling back the rubber boot on the 7 pin adapter, the ground had slipped it’s screw connection. Fifteen seconds with a screwdriver to reattach the ground and check the rest of the wires and we’re in business.
I have to be fair and say that my mechanical Lazy Boy recliners through the years have been fine. My wife’s power recliner gets treated a bit unfairly because of a 65 lb dog that thinks the foot board makes a fine lookout spot to be near his mama, and launches up there if given the chance. She likes it, he likes it, I’m the retired maintenance machinist here, so I fix broken chairs and she cooks.BTDT - Lazy-boy ain't what they used to be - went to other brands when we replaced LR recliners.
For the fun of it?Why'd you make it if it has no use to you?
And it’s always easier to find a reason NOT to do something.For the fun of it?
Too early for a beer? What sort of blasphemy is this you speak of?Sat and de-sweated after putting down fertilizer front and back this morning. Figured 9am was too early and too cold out for a beer. Settled for bottled water and some FM.
You might check with the fire station. Or, a local fire extinguisher company.
Here, in LA County, we have several HHW (Household Hazardous Waste) drop-off points that will take them. Surprised yours won't.
Spray them into the woods, knock the head off with an axe or sledge, then puncture them with a pickaxe. Then you can drop them at the recycler's.
