OP, if you really don't plan on using the thing much, this was $90 when I stopped by my local Walmart
https://www.walmart.com/ip/HART-8-Gallon-Oil-Free-Quiet-Air-Compressor-135-PSI/5135218418
I haven't used this model but the similar "Goodyear" branded model they had a few years back was every bit as quiet as my CAT compressor and a bit more capacity.
If you never really get around to needing lots of air, this looks like a really good option (again no first hand knowledge). Relatively small and light. Plenty of power to inflate tires/use an air gun. Quiet enough that you won't care that it takes longer to refill. Priced right.
