as per title. any issues? I am going to be fabricating some cabinet door hinges for a friend to match an existing profile that's probably not available . I will be starting with 4" **** hinges and doing some grinding , welding , drilling & tweaking . some of the detail is very fine , a cut off wheel would help a lot but in an angle grinder I won't have the stability that a bench grinder would have.
any issues ? I guess RPM is the major concern ... what's a typical RPM of a bench grinder vs an angle grinder?
edit, got my answer on RPM. any other issues?
