Cruzan80
Referring to the brushless impact... While I am sure this one is more biased in the "forward" direction, vs reverse, it actually claims more torque than the 3/8 impact gun (this works out to 175ft-lbs, vs the 3/8 being 165).daily deal online only (do we need a cman v20 thread?)
First unboxing is that it is much shorter/lighter than the previous impacts I have owned (not brushless), and (in theory) I like moving the light location so it hopefully isn't shadowed by the bit.
Like most of them nowadays, I would look at specs of the specific one you are buying, as they seem to make multiple versions that look very similar (IIRC, there are at least three other impact drivers in the V20 lineup).
Also, to give a sense of scale, the head is just slightly longer than the battery itself (the hex collet portion is half-covered when held next to each other).
