^ a very good friend of mine died of sepsis. not something to fool around with. I believe the situation is under control at this point.
Nice pickup! I have one minus the top and cover. A friends father turned it into his road box on his work truck. Someday I hope to get it all together….I spotted this Beach box on FB MP five hours after posting and sent a message to a friend, asking if he was interested; since he'd mentioned wanting some boxes. Five hours later, I replied for him, since he does not use FB and we were first in line. Thankfully, he was able to make the purchase and all I had to do was play keyboard middle-man. The outside is a little rough, but once the cover is up, it looks well worth the $25 asking price. (photos from the ad)
I had to involve my friend before replying, because I was afraid I'd want to keep it.
This is a fantastic find, 1982FXR!!! CONGRATULATIONS!!!Any idea on year? Only OTC roller I've ever seen in person, or maybe at all.
That would hold a metric shitton of Coleman parts and tools!Found this Coleman box on FBMP and had to have it. Steel cabinet with sixteen drawers. Needs a bit of help, but really well made and heavy. Will have no trouble filling it with tools and hardware, that has been looking for a home for a while. It was about a four hour round trip to bring it home.
Anyone seen anything like this? It is actually two banks bolted together. In my search, I found what might be newer stuff by Coleman, but nothing this old, assuming they are from the fifties or so.
I’m right there with you, and I’m not a Coleman aficionado. That cabinet looks like a home made, let’s add whatever handles we have box. Since the top (& maybe bottom) is a single piece, not sure about two separate pieces bolted together. Is the top steel, MDF , plywood, or solid wood. I see the vertical divider is split tho.TBH, I'm thinking the decal was added - it may have come from a Coleman repair shop or factory, but I can't recall seeing any parts organizers like this.
I'm sure that wasn't a Coleman chest. It may have been at a Coleman service center, but most of those serviced a LOT more than just GPAs--reels, guns, etc. I'll bet someone just slapped that (apparently) water-slide decal on there.TBH, I'm thinking the decal was added - it may have come from a Coleman repair shop or factory, but I can't recall seeing any parts organizers like this.
What I have seen:
Metal trays with hinged cover,
Wood wall racks with jars
Akro-Mils organizers (labeled Coleman on the sides and back)
Blue Box 32" x 10" H x 8" W - has two hooks welded to the interior, which I assume is to hold a saw.
Hand hold per chance? Any sign of one oh the opposite end? Maybe it was so a previous owner could drag it off a shelf when stored.![]()
This feature has me puzzled. What purpose do these little widgets serve that are attached to the ends of the box
I agree - the type with the metal D rings.Hand hold
I've seen that on other things to pull them off a shelf. Then carry that sucker one handed, like a real man. Not me, i'd need wheelsonly has those at one end, and they appear to be factory - they're riveted on.
But remember with a carpenter using it, especially a rough Carpenter. You would only have a few saws and measuring tools. Maybe a level. They typically would use a chisel or slick to fix something rather than a plane.I can carry it with one hand - empty.
Not sure I'd be able to lift it after I filled it up with a bunch of steel objects.
A quick flat handle I made using a leather bootlace. Something like paracord could also be used.I'll have to fabricate something. Maybe just a rope loop!
