Do you have any left?Hey Matt,
I re-did a Dayton grinder and my labels are in poor condition. Can you please take a look at the attached and let me know what you might be able to do? I'd really like the main motor label and on/off switch label re-done in aluminum. I did manage to save them in the resto but they detract. Also, the top safety sticker would be a bonus or really any age appropriate "PUT ON YOUR GLASSES" style label would be great...I need the reminder
Original photo:
After resto:
Additionally, I had some Baldor vertical vinyl stickers made for my sander. The creator was kind enough to send me some additional color options so, I can pass these along if anyone can use! White or some shades of blue....
Finally getting to a single phase twin to this grinder & it needs a new data plate due to fading.Is this image clear enough to create a duplicate? A single voltage 3 phase 200V grinder is not as common as the 230/460V 3 phase, or 115/230V single phase models . For those who don't know, 200V is for use on a 208V system.
When I bought my grinder the tag was missing, it came from a school in Truckee, CA.
Matt, the red warning on the nameplate looks like it should be "A MINIMUM OF 4 WRAPS OF CABLE", not "A WRAPS"?
I’d like to buy some of these. Mine measure 4 inches long and 1.5 inches tall.
Sioux Tools Valve Grinder reproduction tag. This is one of that larger labels I’ve made at 12” in diameter. All I had was a photograph of the original but that was enough to make an accurate reproduction. Printed then a clear gloss lamination was applied. I can’t want to see it installed!
Before:
After:
Hi Matt, I have a Delta floor standing drill press that has been fully restored. It is running beautifully. My only finishing touch is the 2" diameter badge that mounts onto the front of the belt guard. It is so faded and beat up that I can't bring myself to mount it back on the machine. I was wondering if you could possibly work your magic to produce a replacement on aluminum for it? You can get a feel for what the colors are supposed to be by looking at the left side mounting hole where some of the original paint is still visible. It looks like the lettering is actually yellow against a red background, with the triangle black. The closest I was able to find online appears beneath it.
