neophyte
Hilti annoyingly doesn’t list info like this in the USA.
They do however actually make tools for US blade standards though, which is less annoying than Festool.
Curious how well those will hold up. Let us know.
Do they still sell soda in glass bottles with caps at the grocery stores? All I've ever seen in over ten years are plastic bottles with screw caps.
Oh you want it. I love the fact they have a smaller battery.Thinking about getting one of those 12v bosch drivers you got there. Haven't decided if I want the impact or not though. Let me know what you think of the two.
Dewalt still offers a cordless drill with a three speed gear box, with 2000rpm rotation.
(I have no clue about noise).
(If I recall correctly, Dewalt, or maybe Hilti were the first to offer an gear for higher speed in a cordless drill).
20V MAX* Brushless Cordless 1/2-In. (13mm) Hammer Drill With (2) 5.0 Ah Batteries And Charger
Complete tough drilling applications with the 20V MAX* XR® brushless cordless 3-speed hammer drill/driver. Featuring a heavy-duty ratcheting nitro-carburized metal chuck with carbide inserts for superior bit gripping strength and a high-efficiency brushless motor, this tool delivers impressive...www.dewalt.com
Fein makes a cordless drill with a four speed gear box with 430/850/2000/4000rpm rotational speeds.
But with the Fein you would need to buy into the AmpShare system.
Festool also offers a four speed drill, but again, different battery system.
Hilti offers a four speed drill as well, but the top speed is around 2200 rpms.
All of these drills either come with, or can use an all steel chuck.
Of course the negative with the non-Dewalt drills would be battery systems.
Fein supposedly actually makes their tools for industrial users, so they include sound and vibration information.
Dewalt and Hilti don’t list sounds specs, at least on their US sites, although maybe if you can find the equivalent models on Euro sites the information would be listed.
Mexican Coke comes in glass bottles, and you even need a bottle opener.
Yes, glass bottled soda still exists.
Other than Mexican Coke, there is Virgil’s Root Beer, and other Virgil’s beverages,
various “premium” sodas routinely sold at places like Whole Foods and other “Health Food” stores,
Various beverage brands probably made in South and Central America, for brands based in those areas, that are routinely available at Walmart,
Various brands sold at Trader Joes, etc.
That is ridiculous and proof that these stores are run by idiots without a lick of common sense. Pop the piece needed from the set on the shelf and do whatever they'd normally do with the originally purchased set had you returned the entire thing. SMART folks might then discount the new set missing a piece and meanwhile have it on hand for further warranty claims. Hmm, who operates like that in the tool world?That’s what I figured. Lowes is the same way about exchanging a screwdriver or a socket. Gotta bring the whole set back.
You are not alone. I have had way more success welding a nut to something than using any extractor regardless of type.No comment on Icon intended here, but I very rarely have been able to get good results using spline type extractors: only if the head snaps off and it is not otherwise damaged and just need a little bite to get the lower portion out.
All that being said, it is generally best to have multi types of options for extractions and also have some luck!
One of the Dewalt screwgun models runs at a max speed of 4850rpms.Thanks for the info.
The DeWalt 20V battery drill I have is 3 speed: But on the highest speed setting, I think my drill is only hitting 2,200 rpm. That is not fast enough to rapidly drill small diameter holes by hand. My DeWalt 20V impact driver with a hex chuck is likely hitting 3,200 rpm peak or a bit more. That seems to be a good speed for rapidly drilling common small hole sizes ~1/8" to 1/16" for predrills for screws and any countersink (if needed in harder woods). So I would like to see a max speed of around 3,200 rpm - 4,000 rpm. I do not think DeWalt makes drills with that high rpms at present -- however they are plenty slow in low speeds for drilling large holes with a lot of torque (actually enough where you need to be careful if they bind). Lightweight and balance can usually be met by using the drill or impact with smaller batteries around 2 Ah capacity. I find I can go quite some time with both drills and impact with 20V, 2 Ah battery packs. IF I am doing a lot of drilling and driving, I keep one battery in the charger while using another and swap every now and then. It does not slow me down and reduces use and positioning fatigue keeping small battery packs in the tools.
That is a good suggestion on looking at Euro vendors for noise specs. It also makes sense that industrial users would be concerned about noise for workers potentially doing something repetitively all day. I user battery impact and drills pretty heavily in spurts in my extensive DIY work. I am pretty sure the DeWalt drills when hammer drilling are way out of bounds with the risk of induced hearing damage. Realistically, one should wear some ear protection hammer drilling in concrete. But external cups over plugs is very uncomfortable to work in when it is hot.
By the way, I have noticed the last few years that DeWalt battery packs with small Ah capacity (I would have thought they use the same cells in all) have become junk. I am not sure if they replaced their vendors for more profit (switch from Korea or Japan cells to China?) and that is impacting life with stronger drain cycles on small packs (I often run them to near depleted). But after having battery packs last easily 5+ years with spurts of very heavy use, they are showing up bad on purchase or dying within a year to two years of use now. DeWalt has been pretty good about the warranty without too much hassle. However, it is still a pain and I have no faith of them working long after the few year warranty cycle at this point. When the battery dies, I temporarily go back to using larger batteries (5 Ah or even a 9 Ah I have for a string trimmer + blower). That strongly reinforces the benefit of using small battery packs on ergonomics, fatigue, and positioning (impacting quality of work). It is odd to me that DeWalt usually sell drill and impact kits with larger 5 Ah batteries. I suspect this is because your average big box store customers think that the larger capacity numbers are all for the better without much thought on tool weight or balance in use.
Glass is a much better storage container relative to plastic. It is not air permeable and the surface is inert. On the downside it is HEAVY to ship and more breakage prone with inevitable oopsies. It probably also takes a lot more energy to make if not recycled.
Long ago coke etc was distributed in glass recycle (meaning return for deposit, then wash out and refill -- which takes much less energy than melting down or processing from raw materials) bottles in the USA. Those days are long gone. That deposit, wash, refill model may make some sense in terms of a storage quality and energy use perspective. But as many know, us Americans are notorious worldwide on being able to eat anything regardless of quality or lack thereof. I remember reading years ago in the 1st gulf war that the Egyptian army was gifted some US army MRE (Meals Ready to Eat) prepackaged for soldiers. They could not believe that army solders from a rich country were eating MREs without a mutiny. Our soldiers ... mostly no issues with them. Ah, the advantages of being raised on canned spaghetti-o's !!! At least if one makes it to middle age in reasonable health without several bouts of bowl cancer ...
Have you used thePressol Oiler 125ml 06 864
Ballistol universal oil 500ml
Another one of these oilers for treating tools and equipment. Many of my larger tools are in a non temperature controlled shed, and so are prone to condensation, and at risk of eventually rusting.
Yes. You saw the first one linked, that's a year ago now. It's fine, just keep enough tube out and keep it fuller than 1/3rd.Have you used the
I'm really hoping you'll like it because I ordered one
Will that calibrate my "Mk I tire checker foot"?I bought a modern scan tool. I wasn't eager to, not at all, but the missus has brought two modern cars into my life that are giving TPMS headaches, so here is the Autel TPMS tool. $220.30 from Amazon before tax.
Fiddled with it some the other day and, well, this is going to take more homework. I started to get the impression that all four sensors of the big white van are snoozing or dead, but it can talk to a sensor I know is working on the old BMW.
I did register it and update its software, which was my first worry. That can be done over wifi, so I am not chained to the "own a PC type computer" path.
I picked up a couple of each of those on the last trip to Menard's. Now that we have one in Athens, I don't have to wait until a trip to Columbus.
