Below 265 SQ/FT Its a bird, its a plane... its a tiny shop! Also know as The Hole.
All workspaces below 265 squarefeet.
bmwrd0
Beaver Fever Oregon
Spent the most of the day in the actual garage (which is out back, off the alley), scraping paint off of the Dalton. Going from this
to this
and this
I am going to need a lower stool to get at the very bottom (it is so much fun getting old), but now I have three sides mostly cleared, and it really looks better.
bmwrd0
Beaver Fever Oregon
I also pulled the spindle caps off and the spindle out to find the bearing surfaces in great shape,
and started inspecting the mast and countershaft pulley, mostly to see how I want to go about rigging it, as it is missing the front motor support bracket, along with the housing that the reversing lever sits in and allows that action
There is a drum with the planetary gears you can see on the left ride in, which I have, but I am not sure about the braking system for the change, and might just go with a simple reversing motor, at least until I can get some sort of documentation on how it works, as there is no known manual or parts diagram.
Here you can see where the support shaft rides. That is an easy "fix" as I can fab a bracket for the front of the lathe and just get a rod to use as a support.
Here it is with the paint getting removed, and showing the black japaning
and here is a pic of everything that the lathe came with
steady and follower rests, change gears, face plate, lantern tool post, and the parts for the planetary gears. Very happy with both rests being there, as there are basically no parts available for these.
(I had meant to post this update two weeks ago, and just realized I hadn't. Sorry for that)
bmwrd0
Beaver Fever Oregon
State of the shop, controlled chaos:
a lot of stuff coming and going, and as it is summer I don't do too much down there, as it is a basement shop and there isn't a good air source that doesn't let heat in. But I do need to move more stuff/junk out to get it to the Restore, and free up floor space to at least move around easier. But, rifles need to be cleaned, cabinets need to be mounted, and so on. A work in progress remains in progress.
When I do work down there this time of year it is usually early in the AM, and right now that is focusing on cleaning small parts for the Dalton
Headstock and tailstock cleaned up
small parts needing cleaning:
just filth
covering evidence of old repairs
but we still need to keep cleaning the goop off.
Also managed to pick up a Makita cut off saw for $5, although it needs a new cord.
this will end up living in the old garage out back, a perfect place for the mess these things make.
Until next time, tschüß!
