Between 265 & 485 SQ/FT My new garage in Wales
sawduststeve
Havering-Atte-Bower,London/Essex boarders, England
Drizzly and horrible weather again this morning. Got soaked to the skin walking the dogs. :rolleyes:
Crikey
It’s 30/86* here already at 10.30.
Dog is staying in the shade today.
Pool is up and running and looking inviting.
Not sure if this helps.
Keep dry.
Steve 🍻
Z
Zebedeewesty
Wales, UK
Gonna have to replace a pair of tyres as they've got age related/UV cracking on the sidewalls which is annoying as they've only done a couple of thousand miles.
Its running 195/70/15 on stock steel rims but i'm not sure whether to go with summer tyres or to fit all seasons. Theres only around a £5-£10 difference if you shop around.
I know all seasons are a bit of a compromise (not as good as a summer in the summer months and not as good as a winter in winter funnily enough). Some reviews i've seen say you lose a little MPG (its a 2.5 petrol auto so giving **** mpg anyway but i'd rather not get less), that they're a bit noisier than summer tyres and wear quicker. They're likely to need replacing due to age before they wear out so thats not really a problem.
Really not sure if all seasons are worth it.
Z
Zebedeewesty
Wales, UK
Finally found why the AC wouldn't switch on the fans or compressor clutch. A badly repaired wiring plug at the pressure switch (the wires were just twisted together and pushed into the plug) so it was barely making contact. Waggling the plug made the clutch engage and the radiator fans spin up.
Chopped off the plug and used a couple of spade connectors until i can get a new plug.
It was 31c (88f) in the van which dropped nearly 10 degrees in 10 minutes with the AC on. Not sure how cold the air coming from the vents is but it seemed pretty cold.
It might possibly still need a top-up as hadn't worked in quite a few years before we bought it.
We had a quick rain shower this afternoon at around 4pm. Only 10 minutes long so it didn't make a difference to how muggy it feels outside. Still in the high 20s celscius.
Z
Zebedeewesty
Wales, UK
Just had the spare tyre swapped on our Autosleeper. Yep, that's a 1992 date code. It still had the little whiskers on the tread so it's never seen the road in its whole life.:oops:
Nice new pair of Maxxis Vansmarts fitted to the front.
I parked in the shade in the supermarket carpark but it was still nearly 30c (86f).
Sun had moved round so the caravelle was back in the sun again when i came out of the supermarket.
Z
Zebedeewesty
Wales, UK
I used to think of new tires as cheap insurance. With today's prices, I'll just say Good insurance!
Our caravelle came with nearly new Continentals when i bought it and you could throw it into a corner and it'd stick like sh!t to a blanket. When they needed replacing i priced them up at £140 ($185) a corner fitted so went for budget ones at a 1/3 the price as money was tight and the difference was like night and day. On the same corners i could go into at 55-60mph with the Continentals it struggled at 1/2 the speed.
I bought mid range tyres after that and though not up to the continentals its made a helluva difference.
Z
Zebedeewesty
Wales, UK
Reached 33c (91.4f) here yesterday and was still 24 at night which wasn't nice. Had a fan running in the bedroom but my missus complained it was too loud (its just over whisper quiet) and the breeze was also setting off her trigeminal neuralgia.:rolleyes:
It was a bit cooler this morning when i took the dogs out and there was a slight breeze too. (y)
Just looked out of the window and its so misty you can't see across the fields. :oops:
Z
Zebedeewesty
Wales, UK
Hot in the summer house today
Yeah, our conservatory has been 37c or so.
This is the max temperature my garage loft had reached on thursday. So glad i insulated it as it was mid to high 40s up there the first summer we were here.
Quite a reasonable temperature out this morning. Rain overnight again, though no thunderstorms.
Z
Zebedeewesty
Wales, UK
Congratulations on the win! Are you going to be able to find a NOS bumper or a good reproduction? Or are they getting hard to find?
I got a decent mid range quality one. The cheap ones are thinner steel and virtually bendable by hand. The chome is normally the first thing to go, though it's not living outside so hopefully it'll last a bit longer. Triple chrome plated ones were £200 ($267) more. I don't think I've seen a NOS one in about 20 years.
Z
Zebedeewesty
Wales, UK
Been a reasonably warm weekend. Glad we parked in the shade.
2026-07-05 11.13.17.JPGFridge decided to fail to cool on propane. :rolleyes: I think it might be a partially blocked burner or jet. You can see a nice blue flame through the sight glass in the back of the fridge but it just wasn't cooling. Just what we needed. Warm ciders and milk. :(
Few piccies from the car show today. Not a lot of vehicles there.
