rattle_snake's random shop projects v0.1
SilverJimmy
Prescott/Flagstaff, AZ
I have solved the soggy cheese in the cooler problem by using frozen bottles of water. Instead of ice I put 6-8 bottles of frozen water in with the food and drinks. Keeps everything nice and cold and as a bonus towards the end of the day I have some ice water to drink. I keep the same number of bottles in the freezer in our camper and just rotate them for any day trip we might take.
ntsqd
Lower left coast
One of the things that Locos Mocos taught me was to only drain enough water out of the cooler to gain enough room for more ice. This is contrary to everything else that I'd ever seen or been told, but it makes some sense when you really think about it.
With a cooler full of water and ice it's all at 32° or colder (in the case of the ice) and it can't get any warmer until almost all of the ice has melted. Water is a massive thermal sink, it takes a huge amount of heat to change 32° ice into 32° water, and quite a bit more heat to raise the water to 33°. In contrast it takes very little heat to raise air's temperature by one degree.
Water & ice is also an excellent suspension media for the beer & eggs. A full-on flogging down a section of the race course won't foam the beer nearly as badly if the cooler is full of water and ice. It will definitely foam it if you've drained all of the water out, and the ice won't last anywhere near as long.
R
rattle_snake
Chandler, AZ
I see the price of 12 VDC fridges has come down significantly in the last few years. I have a pair of lifetime small and medium size ice chests that do the job well.
That said I spent some time on the cabover camper 3-way fridge. It will light but not stay burning. Long ago a took it apart and determined that the design of the thermocouple wiring drops to much voltage across the various contacts to work reliably.
Aside from modify/repair an option is to replace the old fridge with a modern 12 VDC compressor type and abandon the gas. Would need a solar setup to run it, which I'm considering anyhow. Or even another 12 VDC portable to use on the ground outside, and for trips without the camper.
Also thinking of long run, the 110 VAC rooftop AC is 20+ years old. My Honda inverter generator struggles to run it, which it didn't before. Setup still works but is loud. A 48 VDC air conditioner, decent battery setup and panels would be a nice upgrade.
zmotorsports
Northern Utah
We do the same thing Sterling. Our drinks are in the cooler with the ice, but our lunches go in a smaller soft-sided cooler using frozen water bottles to keep everything cool. Works like a dream and just keep rotating new ones into the freezer so there's always 4-6 frozen and ready for the next day(s).
SilverJimmy
I just upgraded or Arctic Fox 990 truckbed camper to a Dometic 12 volt compressor fridge. The camper already had a 200 watt solar panel so I also upgraded the batteries to two 105 amp hour lithium batteries at the same time. We just got back from a 3-1/2 week trip to Yellowstone and all points between and the new fridge has been rock solid, fridge at 33 degrees and freezer at -3 degrees always! Best thing I ever did and now the wife is happy, no more fridge failures! We also did a trip to ElMirage last May and the solar kept up perfectly with the fridge power draw.
R
rattle_snake
Chandler, AZ
Spent some time on the RV fridge, studied the schematic and determined that the problem is still the selector switch. Obsolete part. It's a multi pole switch (AC/DC/Gas) and the gas aspect is only one contact. It connects the thermocouple to the gas valve. Hack was to extend the two gas related wires and use a simple rocker switch for gas mode, on/off. Downside is the extra switch doesn't prevent multiple power sources. But it works good and has run for a few days. Going to call that a win and move on.
Still not decided on the solar aspect. Don't need solar system and have done without so far. Daytime charging would be a 'nice to have'. Perhaps a portable ground setup would make more sense and be able to be used beyond the cab over camper. Otherwise a single 100W panel would do the job and would remove the need to plug in the camper when stored.
R
rattle_snake
Chandler, AZ
Spent most of a day doing maintenance on quad. Don't have a log to know when last services were so doing everything and created a log. The lift and oil drain can make the job much easier. Did engine oil/filter, trans, rear end and coolant.
That leaves front e-lock diff and brake fluid. All suspension bushing and CV boots are still good.
Probably didn't need any of the fluids, but now I know it's good and when next time should be. My kids ride it also so I want it to be as reliable as possible with good care.
R
rattle_snake
Chandler, AZ
Smoked a brisket and ribs on Sunday. Did yard work most of the day, in small pieces, at 110*. Trying to stay on top of yard work this summer. Last summer I didn't care enough to do so.
Fired up the smoker in the morning and it went into error mode 'SEn'. Main temp sensor was way off. Cycle power and smacked sensor a few times. It settled out and ran for the rest of the day.
BBQ drawers were dirty, greasy and unorganized. Time to do something about that. Removed the drawers and cleaned them up with oven cleaner. Made some simple dividers out of plywood.
R
rattle_snake
Chandler, AZ
Chipping away at turd-polishing my camping equipment. Next item is camp table. I avoid multiple or large tables because any horizontal surface get piled with someone else's **** almost immediately. So I have just one small folding table I bought 20 years ago. Simple and light but the material is press wood and has sagged over time. Considered making some type of aluminum frame to support the middle. Decided to try rigid foam to hold proper shape when stored instead. Taped the edges with foil tape to prevent bean going everywhere, and glued down the foam. Made a clamp to shut it tight. Hopefully by next trip the pressboard will be back to flat, and the foam will stay attached. Otherwise the foam can be just for storage.
R
rattle_snake
Chandler, AZ
Finished out the maintenance on my 2004 Polaris 600. Changed front diff fluid. All the brake bleeders were clogged. Resolved that and pulled fresh fluid through the system. Made a mess of course. Checked the pads. Also bleed out the secondary rear brake circuit that is on the shift lockout pedal. It has never worked, supposed to stop before changing gears. Resolved but brake doesn't do much. Since three of the fluids are fill up to the hole and leak out, the chassis had residual mess and I gave it another cleaning. So with that my dirt bike and quad are in tip-top shape ready for the next trip.
I decided to pause on the solar setup on cabover camper. I don't have a clear goal or plan. I went ahead and off loaded it from the truck. Still need to fix the cracked window, needs to be on the ground to do so. But it's cleaned up and ready for the next trip.
Still thinking about how to build out the utility trailer to make it easier to use and secure stuff. Storage areas front and rear and a easier way to secure the machines. For the dirt bike, a better front tire chock and a dedicated loop of some sort. New fork saver, and cut down the straps. To secure the quad, there are many ways. I want fast and easy. Considering adding a small winch to the front of the quad to use for the purpose. Make a rear loop and then **** down the winch. Like a tow truck. Another option are tire tie downs.
ntsqd
Lower left coast
Can really get wrapped around the axle over solar. I just want a system the works without me needing to monitor it more than very occasionally.
With the Bronc-up I bought L Track (airline seat track) & QD tie-downs since the loading was expected to vary.
Surface mount: https://www.uscargocontrol.com/products/96-airline-style-angled-track-aluminum
Flush Mount: https://www.uscargocontrol.com/products/96-flanged-airline-style-track-aluminum
And adjustable location anchors like: https://www.uscargocontrol.com/products/double-stud-fitting
For something like a MC front tire trap that won't always be in place I might use several of these: https://www.uscargocontrol.com/products/l-track-double-lug-threaded-stud-fitting
For heavier loads, like on a car hauler trailer I'd go with E-track, but for a utility trailer I like the flush mount for the deck and the surface mount for any rails or permanent sides it might have. If I keep the '73 C10 SBSS I plan to 'hide' the edge of the bed liner under an upper strip of L-Track.
R
rattle_snake
Chandler, AZ
Not really looking for a tie down system. More of specifically how to secure the machines. Same machine, same place so mounts can be permanent. Fast and easy but secure enough for 800 lb machine on a nasty rocky back road.
Spent some time last night on my 2004 Cobra. The subwoofer box was never really secured well, and gets banged around in the trunk. Knocks the trim off the front. Awhile ago I had changed the strap orientation to diagonal to try to reduce side-to-side movement, but not successfully. Time for v2.0. To combat the side movement I added some 'wings' on the sides of the box that hook into the back seat opening. Needed some spacers to fit properly. The other fix was to re-do the nylon straps and buckles. Made a short loop on box to hold a backpack style buckle, and a 2nd loop on the outer LATCH points. Now I can really snug the straps down. See how it works after some aggressive driving. Also finished cleaning the car, the inside, jams. I live in a dusty environment and it blankets the interior. Next up is an oil change, it's at 4.4k miles which is about my threshold. Ordered M1 oil and filter.
Trying to catch up on life in general before I tear into the 76 F100 front suspension. Been doing a small amount of yard work each day, but it's over 100 even well after dark.
Mark_17
ntsqd
Lower left coast
Can get single point "L-track" anchors. I'm sure that they're effective, but it seems like the only reason to do that is if you're already heavily invested in other L-track hardware.
Sounds to me like flush mount or surface mount D rings are the go-to.
R
rattle_snake
Chandler, AZ
The retractable straps are cool. bolt down.
option b is a small hand winch. The sun will destroy strap material so maybe old school wire rope is the way to go.
Fixed length single strap from quad hitch ball to 2 points rearward on the deck, in a 'V'. Then just cinch up the winch on the front tow hook a few cranks, just like a boat. The existing set of D-rings are only anchored in the wood, so would have to add a pair of dedicated anchors into the frame.
Bought a sheet of #9 3/4 expanded steel and some rem sq tube to build some storage compartments on the deck.
R
rattle_snake
Chandler, AZ
Knocked out the Cobra oil change in record time. Finally having the right tools and equipment is everything. Got to use my bendy drain thingy for the oil filter.
Also did air filter service. Only been 3k miles but the filter is small and down inches off the pavement so it gets really dirty quickly. I wanted to finish the job same day, so after cleaning the filter I used the 'convection oven' to dry the media. Given that the 'cool' air going into the AC condenser is over 112 F, the air coming out is well beyond that. Usually dry cycle is over night, Shortened that to about 3 hours. Needs to be dry as the oil application won't wick into media wet.
While drying, I ordered another filter to have a backup that can be installed without wait cycle. I went with a dry, no-oiled type of the same style and brand (S&B) so that removes the drying time. Same price either way. I want to use the same filter as the MAF is directly connected to the filter, and filter heaily effects the airflow characteristics.
ntsqd
Lower left coast
Gets ugly fast, doesn't it?
I think that's a big part of why, as per the recent discussion in ZMotorsports' thread, most don't cross the straps when dealing with a car or truck on a trailer. With smaller vehicles like a SXS or a quad there isn't enough weight involved for it to be quite as big of a problem, but most would intuitively know that a 1" strap isn't going to work when at a really flat angle. It's when the angles aren't severe is where intuition seems to fail most of us.
R
rattle_snake
Chandler, AZ
Yes, at the rate of sine of angle. :)
When I was a teenager I spent the summers working in Alaska on my uncles commercial fishing site. Kenai river, set net, sockeye. So fishing off the beach, one end of net on beach, the other out in the water on an anchor line loop.
The gill nets used steel spreader bars to hold the cork and lead lines apart in the extremely fast running tidal flow (15-20 knots). Most everyone else did not do that, and just let the weight of the lead do it's thing . But the net won't catch anything that way, parallel to flow, until the tide slows down and it can hang down perpendicular.
Since our nets had the full force of tide on the surface area of net, the pressure on the rigging system was very high. Beyond what even very large rope (over 1") would handle reliably. So we used steel cable for the anchor line, and a dedicated 4x4 vehicle on the other end. Leaving 'too much' net in the water with a big tide would do one of the following
-break the main cable
-drag the anchor in
-destroy the net
-drag the tow vehicle out of position
We had books and charts on rope types, capacities and so on. I found that the infinity angle deal interesting. We broke a lot of things, people got hurt bad. Really dangerous way to make a living.
R
rattle_snake
Chandler, AZ
Started on the trailer modifications. I have underestimated the amount of work needed. I still don't have a clear plan, so going to just build stuff and hope it works out OK.
The goal is to retain the removable aspect of each part of the railing system. Step one is to enclose the area under the rail, so smaller stuff doesn't slide off the deck in transit. The system doesn't have a lower rail, so had to add one to attach the walls to. Used 1" sq 0.120 as that is what I found on the rem pile that day. The trailer is only so accurate, and has been used, so it's not perfectly square in every way. Build in place with little welder then finish weld on bench. Used #9 3/4 expanded steel sheet to fill the area. Cut off all the pipe pegs that I had put on for motorcycle wheel chocks. Not really doing 2 or 3 dirt bike trips much anymore.
I could have built everything in 2" angle like existing (or 2" tube) but that gets heavy and expensive fast. To do it right, just start over on rail system completely.
I could have used lumber to make the storage system I'm after. But the weather will eventually destroy it like the deck. So steel it is, but might use some limited wood if it makes sense.
