Between 265 & 485 SQ/FT The "Glendora Garage"
D
Dan in Pasadena
Pasadena, CA
Some activity here:
Finally, red paint on the footlocker project. I'm not overly happy with it. it's much rougher than the prior one I did but as Kay says it's a knock around truck bed box. It'll get a final sand and final coat. That'll have to be good enough. The corners on this thing are pretty rough. The angle iron around the top hides a lot of that. I wire wheeled it, hammered it flat, sprayed silver and it looks ok. I've done nothing to the interior. yet It'll be sprayed with truck bedliner. Then hinges, handles, etc. I won't post a pic of this wavy surface.
D
Dan in Pasadena
Pasadena, CA
The Fiat 500 "toad" has some flaking clear coat but fortunately only on the leading edge of grille below hood. Because the mirror came out nice I'll use the remaining paint to TRY to improve that area. I'm not sure about blending it in with the rest of the paint.
The break at the hood and even a body line below is where I'll try to blend .....but on the sides I expect the repair to show. Oh well. Not sure I have enough paint to do the entire grille. But it's a thought.
D
Dan in Pasadena
Pasadena, CA
And after a hot day or two, they'll be a total PITA to remove.
They’ll be off the truck the minute the event is over. There’s an “eagle” with “250” on the tailgate. But since the gate isn’t flat it didn’t want to adhere well. Didn’t transfer cleanly so we had to do it by hand. The pieces got stretched and it’s almost comical how it came out. I expect to go outside and see 1/2 of its fallen off!
