Sticker shock! No I didn’t buy.
jack stand
Lakes Region Maine
No TSC or other farm type store ?
Tsc = pet food, clothes and tacky yard ornaments. Hardware by the pound is ok but not so much for being a good "AG" store.
That's probably just a sign of the times to stay profitable in most locations so I'm really not blaming them.
I remember what they used to be 30+/- years ago.
NUTTSGT
Northern Central Ohio
I won't totally disagree with that thought about TSC, however, I have bought zerks there before buying assortments at HF.
jack stand
Lakes Region Maine
I have noticed that the stores inventory seems to be different in relation to the ag activity in the region. Comparing the stores in the mid Atlantic (Appalachian's) area to here in Maine was the reason for my (unfair) sour response.
mm08822
If it doesn't sell frequently off of the local store's shelf, it gets dropped for other items that will.
Local demand at each store can be very different.
Sumboodie
AK
I miss grade 8 bolts by the pound that D&B Supply had when I was in Idaho.
Need 3 bolts? I'd buy a lb or two for spares.
I made the mistake buying a case of ATF at Schucks last week for my forklift. $168....or $56 a gallon.
He told me the price and I was like.... uhhh, are you sure? You mean $68, right?
We sell ATF at work for around half that a gallon and I STILL get people complaining in prices. I think the most expensive one we have, a special order brand, it under $50 a gallon still.
(I wanted to get the project done and didn't need to waste 2+ hrs driving 100 miles to get a pail from work)
OccupantRJ
Eastern North Carolina
These days are over.
Zim
We are lucky here with a local Delmus mom and pop hardware 2-1/2 miles away where you can find most things like mower tires, blades, parts, fertilizer by the pound, plants, propane refills for $12, burn barrels, aisles of hardware, etc. When I first moved here you could rent a commercial portable sandblasting setup from them. I am very thankful for the store still being in operation and run by the daughter.
zimman
Mark Twain National Forest
We have a really good ACE Hardware. Store is packed and if he doesn't have it, he'll find it and order it.
Thanks for that
Zim
niget2002
Josephine, TX
If I need something 'today', I have a few choices.
We have a few TSC's. They seem to be hit and miss sometimes.
If I need something that they don't have, I'll take the trek to Atwoods.
If they don't have it, then I'll look online.
PoorUB
Fargo, ND
The TSC near me has quite a bit of hardware, PTO parts, bearings and more. I would expect them to have a good selection of zerks.
Depending on how bad I needed them I still might order from Amazon and wait a couple days, instead of the twenty mile round trip.
NAPA would be another choice.
kwb
PNW
Ace Hardware locations I use all have Zerks in the hardware section. Harbor Freight does as well (as noted above).
Automotive parts store chains have become nearly useless beyond Batteries, Belts, and most fluids and filters.
H
Hal
Vermont
Nothing in less than forty miles. O’Reilly delivers twice a day.
That’s an oddball piece, and I didn’t expect them to stock it, but I thought they would have it in their system somewhere. WRONG!!
For the ones who suggested various assortments, those are likely all threaded pieces.
As to tapping it out to 1/8” , if I had the shaft out of the bore I would. I don’t want to gouge the shaft, or wind up with shavings in the housing.
And while we’re at it, WhereTF is my good grease gun? I had it at the sugarhouse, it’s not there, not in any of my vehicles, definitely not back at the garage. I have another, but it doesn’t have the Lock-N-Lube nozzle.
NUTTSGT
Nothing less than 40 miles ? Talk about boonies....
Not sure what you mean by the "those are likely all threaded pieces in the assortments.
dante2
Central OK
Zim
I met a MP seller at his house for a table. His shop was loaded out with an old hardware store inventory. Looked like a Fastenal store. He also had a really nice late 60's Bronco restoration almost done. Saved his info just in case.
PCustoms
VT
Bridgton and Windham TSC both show multiple grease fittings in stock...
NHtoolguy
Gilford, NH
This situation was more complicated because the OP needed an unthreaded, drive-in style of zerk fitting with a smooth taper. The assortments listed were the more common threaded, screw-in type. I can't recall the last time I encountered an unthreaded one in service, or needed one.
PCustoms
VT
Agreed, expecting ANYONE to stock a esoteric component is unrealistic
The quick search I did on Amazon I had a hard time finding them, this looks questionable at best
NUTTSGT
I can't recall ever dealing with a drive in zerk.
BillK
Beautiful Southern Maryland
Must be different than the one here. Ours has almost anything you need.
Stuart in MN
Minneapolis
Any Case IH dealers nearby? They may not carry parts for an old Farmall but it would have been worth at least checking. For that matter there's places like Steiner Tractor that specialize in parts for vintage tractors.
manwithtools
Lebanon, TN
Give it time, they will change it. They are shifting to a pet supply and clothing store in most markets. They still have some of what made them Tractor Supply, but it's changing for sure.
LOW1
ontario
I am a bit spoiled. Two Aces, Theisen’s, TSC , Lowe’s and a Menards within ten miles.
Needed some tiny metric machine screws yesterday. Menards had them.
The nearest Ace has a crusty old retired plumber who works on Saturdays and knows how to to it and what you need to get it done.
67King
Friendsville, TN (Knoxville area)
They are my go to for herbicide, though.
cvairwerks
Within hearing distance of Texas Motor Speedway
Claymont: I could if I was only working on personal a/c. Customers get a little squirrelly when you approach their million+ dollar aircraft with hacked up tools.. Still trying to find a local Snap On guy that I can order from when I need things. Outside of some oddball stuff like this socket, I'm pretty well set, so I'm not worth becoming a regular stop. I don't mind catching him somewhere local and paying upfront for what I need and waiting til his next time in the area to pick it up.
